Efficient probabilistic Range-Only SLAM, 2008 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2008. ,
DOI : 10.1109/IROS.2008.4650650
A spectral learning approach to range-only slam. arXiv preprint, 2012. ,
A general Gaussian-mixture approach for range-only mapping using multiple hypotheses, 2010 IEEE International Conference on Robotics and Automation, 2010. ,
DOI : 10.1109/ROBOT.2010.5509704
A Set Theoretic Approach to Dynamic Robot Localization and Mapping, Autonomous Robots, vol.16, issue.1, pp.23-47, 2004. ,
DOI : 10.1023/B:AURO.0000008670.09004.ce
Navigating with ranging radios: Five data sets with ground truth, Journal of Field Robotics, vol.35, issue.9, pp.689-695, 2009. ,
DOI : 10.1002/rob.20311
URL : http://www.ri.cmu.edu/pub_files/2009/9/Final_5datasetsRangingRadios.pdf
A Robust Method of Localization and Mapping Using Only Range, Experimental Robotics, pp.341-351, 2009. ,
DOI : 10.1007/978-3-642-00196-3_40
The LMI control toolbox, Proceedings of 1994 33rd IEEE Conference on Decision and Control, 1995. ,
DOI : 10.1109/CDC.1994.411440
A Nonlinear Set Membership Approach for the Localization and Map Building of Underwater Robots, IEEE Transactions on Robotics, vol.25, issue.1, pp.88-98, 2009. ,
DOI : 10.1109/TRO.2008.2010358
Range-Only SLAM With Occupancy Maps: A Set-Membership Approach, IEEE Transactions on Robotics, vol.27, issue.5, pp.1004-1010, 2011. ,
DOI : 10.1109/TRO.2011.2147110
URL : https://hal.archives-ouvertes.fr/hal-00636000
A Sum of Squares Approximation of Nonnegative Polynomials, SIAM Review, vol.49, issue.4, pp.651-669, 2007. ,
DOI : 10.1137/070693709
An Algorithm for Path Connections and Its Applications, IEEE Transactions on Electronic Computers, vol.10, issue.3, pp.346-365, 1961. ,
DOI : 10.1109/TEC.1961.5219222
Sums of squares of real polynomials, pp.103-126, 1995. ,
DOI : 10.1090/pspum/058.2/1327293
High resolution maps from wide angle sonar, Proceedings. 1985 IEEE International Conference on Robotics and Automation, 1985. ,
DOI : 10.1109/ROBOT.1985.1087316
Interior-point Polynomial Methods in Convex Programming, 1994. ,
DOI : 10.1137/1.9781611970791
Robust Range-Only Beacon Localization, IEEE Journal of Oceanic Engineering, vol.31, issue.4, pp.949-958, 2006. ,
DOI : 10.1109/JOE.2006.880386
URL : http://groups.csail.mit.edu/rvsn/content/eolson/robl/eolsonAUV2004numbered.pdf
Robust and Optimal Sum-of-Squares-Based Point-to-Plane Registration of Image Sets and Structured Scenes, 2015 IEEE International Conference on Computer Vision (ICCV), 2015. ,
DOI : 10.1109/ICCV.2015.237
An algorithm for sums of squares of real polynomials, Journal of Pure and Applied Algebra, vol.127, issue.1, pp.99-104, 1998. ,
DOI : 10.1016/S0022-4049(97)83827-3
An efficient least-squares trilateration algorithm for mobile robot localization, 2009 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2009. ,
DOI : 10.1109/IROS.2009.5354370
