Map merging of Multi-Robot SLAM using Reinforcement Learning, 2012 IEEE International Conference on Systems, Man, and Cybernetics (SMC), 2012. ,
DOI : 10.1109/ICSMC.2012.6377676
6D SLAM???3D mapping outdoor environments, Journal of Field Robotics, vol.23, issue.8-9, 2007. ,
DOI : 10.1109/TRO.2004.829506
A flexible and scalable SLAM system with full 3D motion estimation, 2011 IEEE International Symposium on Safety, Security, and Rescue Robotics, 2011. ,
DOI : 10.1109/SSRR.2011.6106777
URL : http://www.sim.informatik.tu-darmstadt.de/publ/download/2011_SSRR_KohlbrecherMeyerStrykKlingauf_Flexible_SLAM_System.pdf
Comparing ICP variants on real-world data sets -open-source library and experimental protocol, Auton. Robots, 2013. ,
DOI : 10.1007/s10514-013-9327-2
URL : https://hal.archives-ouvertes.fr/hal-01143458
Efficient Large-Scale 3D Mobile Mapping and Surface Reconstruction of an Underground Mine, FSR, ser. Springer Tracts in Advanced Robotics ,
DOI : 10.1007/978-3-642-40686-7_32
Zebedee: Design of a Spring-Mounted 3-D Range Sensor with Application to Mobile Mapping, IEEE Transactions on Robotics, vol.28, issue.5, 2012. ,
DOI : 10.1109/TRO.2012.2200990
Continuous 3D scan-matching with a spinning 2D laser, 2009 IEEE International Conference on Robotics and Automation, 2009. ,
DOI : 10.1109/ROBOT.2009.5152851
Loam: Lidar odometry and mapping in realtime, Robotics: Science and Systems, 2014. ,
DOI : 10.15607/rss.2014.x.007
URL : http://roboticsproceedings.org/rss10/p07.pdf
Fastslam 2.0: An improved particle filtering algorithm for simultaneous localization and mapping that provably converges, Proc. of the Int. Conf. on Artificial Intelligence (IJCAI, 2003. ,
Merging of octree based 3D occupancy grid maps, 2014 IEEE International Systems Conference Proceedings, 2014. ,
DOI : 10.1109/SysCon.2014.6819283
Probabilistic octree modeling of a 3D dynamic environment, Proceedings of International Conference on Robotics and Automation, 1997. ,
DOI : 10.1109/ROBOT.1997.614315
Mapping and Exploration of Complex Environments Using Persistent 3D Model, Fourth Canadian Conference on Computer and Robot Vision (CRV '07), 2007. ,
DOI : 10.1109/CRV.2007.45
3D forward sensor modeling and application to occupancy grid based sensor fusion, 2007 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2007. ,
DOI : 10.1109/IROS.2007.4399406
URL : http://robotics.jacobs-university.de/publications/IROS07_3D-RangeSensorFusion.pdf
Real-Time SLAM with Octree Evidence Grids for Exploration in Underwater Tunnels, Journal of Field Robotics, vol.12, issue.1-2, 2007. ,
DOI : 10.1002/rob.20165
OctoMap: an efficient probabilistic 3D mapping framework based on octrees, Autonomous Robots, vol.11, issue.3, 2013. ,
DOI : 10.15607/RSS.2007.III.017
URL : http://www.informatik.uni-freiburg.de/~stachnis/pdf/hornung13auro.pdf
Humanoid robot localization in complex indoor environments, 2010 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2010. ,
DOI : 10.1109/IROS.2010.5649751
URL : http://ais.informatik.uni-freiburg.de/publications/papers/hornung10iros.pdf
Robust and efficient multirobot 3-d mapping merging with octree-based occupancy grids Supervised feature type selection for topological mapping in indoor environments, 21st Signal Processing and Communications Applications Conference, pp.1-4, 2013. ,
Visual-lidar odometry and mapping: low-drift, robust, and fast, 2015 IEEE International Conference on Robotics and Automation (ICRA), 2015. ,
DOI : 10.1109/ICRA.2015.7139486
URL : http://www.frc.ri.cmu.edu/%7Ejizhang03/Publications/ICRA_2015.pdf
Multiple View Geometry in Computer Vision, 2004. ,
DOI : 10.1017/CBO9780511811685
3D is here: Point Cloud Library (PCL), 2011 IEEE International Conference on Robotics and Automation, 2011. ,
DOI : 10.1109/ICRA.2011.5980567
URL : http://www.pointclouds.org/assets/pdf/pcl_icra2011.pdf
Efficient variants of the ICP algorithm, Proceedings Third International Conference on 3-D Digital Imaging and Modeling, 2001. ,
DOI : 10.1109/IM.2001.924423
A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, 1992. ,
DOI : 10.1109/34.121791
