Abstract : Magnetic resonance imaging is performed without ionizing radiation, however, the applied radio frequency power leads to heating, which is dependent on the body part being im-aged. Determining the patient position in the scanner allows to better monitor the absorbed power and therefore optimize the image acquisition. Low-resolution images, acquired during the initial placement of the patient in the scanner, are exploited for detecting the patient position. We use Laplacian eigenmaps, a manifold learning technique, to learn the low-dimensional manifold embedded in the high-dimensional image space. Our experiments clearly show that the presumption of the slices lying on a low dimensional manifold is justified and that the proposed integration of neighborhood slices and image normalization improves the method. We obtain very good classification results with a nearest neighbor classifier operating on the low-dimensional embedding.
