Time-Stepping Numerical Simulation of Switched Circuits Within the Nonsmooth Dynamical Systems Approach, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.29, issue.7, pp.1042-1055, 2010. ,
DOI : 10.1109/TCAD.2010.2049134
Nonsmooth Modeling and Simulation for Switched Circuits, Lecture Notes in Electrical Engineering, vol.69, 2011. ,
DOI : 10.1007/978-90-481-9681-4
URL : https://hal.archives-ouvertes.fr/inria-00522358
Higher order Moreau???s sweeping process: mathematical formulation and numerical simulation, Mathematical Programming, vol.43, issue.4, pp.133-217, 2008. ,
DOI : 10.1007/BFb0109998
URL : http://www.inrialpes.fr/bipop/publis/AcBrGo2008MATHPROGA.pdf
Numerical simulation of piecewise-linear models of gene regulatory networks using complementarity systems, Physica D: Nonlinear Phenomena, vol.269, pp.103-119, 2014. ,
DOI : 10.1016/j.physd.2013.11.013
URL : https://hal.archives-ouvertes.fr/hal-01103557
A General-Purpose Software Framework for Dynamic Optimization, ESAT/SCD) and Optimization in Engineering Center, p.3001, 2013. ,
Generalized discontinuous conduction modes in the complementarity formalism, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.52, issue.8, pp.52447-451, 2005. ,
DOI : 10.1109/TCSII.2005.849010
Some perspectives on the analysis and control of complementarity systems, IEEE Transactions on Automatic Control, vol.48, issue.6, pp.918-935, 2003. ,
DOI : 10.1109/TAC.2003.812777
URL : https://hal.archives-ouvertes.fr/hal-01660014
Some results on the controllability of planar variational inequalities, Systems & Control Letters, vol.54, issue.1, pp.65-71, 2005. ,
DOI : 10.1016/j.sysconle.2004.06.006
URL : https://hal.archives-ouvertes.fr/inria-00071798
On the equivalence between complementarity systems, projected systems and differential inclusions, Systems & Control Letters, vol.55, issue.1, pp.45-51, 2006. ,
DOI : 10.1016/j.sysconle.2005.04.015
URL : https://hal.archives-ouvertes.fr/inria-00071475
Well-posedness, stability and invariance results for a class of multivalued Lur???e dynamical systems, Nonlinear Analysis: Theory, Methods & Applications, vol.74, issue.1, pp.195-212, 2011. ,
DOI : 10.1016/j.na.2010.08.034
URL : https://hal.archives-ouvertes.fr/hal-01633239
Existence, uniqueness of solutions and stability of nonsmooth multivalued Lur'e dynamical systems, Journal of Convex Analysis, vol.20, issue.3, pp.881-900, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00825601
Existence and uniqueness of solutions for non-autonomous complementarity dynamical systems, Journal of Convex Analysis, vol.17, issue.3, pp.961-990, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00756226
Optimal control of a perturbed sweeping process via discrete approximations, Discrete and Continuous Dynamical Systems - Series B, vol.21, issue.10, pp.3331-3358, 2016. ,
DOI : 10.3934/dcdsb.2016100
Lyapunov Stability of Complementarity and Extended Systems, SIAM Journal on Optimization, vol.17, issue.4, pp.1056-1101, 2006. ,
DOI : 10.1137/050629185
Consistency of a time-stepping method for a class of piecewise-linear networks, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.49, issue.3, pp.349-357, 2002. ,
DOI : 10.1109/81.989170
On Linear Passive Complementarity Systems, European Journal of Control, vol.8, issue.3, pp.220-237, 2002. ,
DOI : 10.3166/ejc.8.220-237
Passivity and complementarity, Mathematical Programming, vol.11, issue.4, pp.531-563, 2014. ,
DOI : 10.1002/rnc.592
Optimization-Theory and Applications: Problems with Ordinary Differential Equations, 2012. ,
DOI : 10.1007/978-1-4613-8165-5
Optimal control of the sweeping process, Dyn. Contin. Discrete Impuls. Syst.-Ser. B, vol.19, pp.117-159, 2012. ,
Optimal control of the sweeping process over polyhedral controlled sets, Journal of Differential Equations, vol.260, issue.4, pp.3397-3447, 2016. ,
DOI : 10.1016/j.jde.2015.10.039
The linear complementarity problem, SIAM, 2009. ,
Finite-dimensional variational inequalities and complementarity problems, 2007. ,
Switching, relay and complementarity systems: A tutorial on their well-posedness and relationships, Physica D: Nonlinear Phenomena, vol.241, issue.22, pp.2411985-2002, 2012. ,
DOI : 10.1016/j.physd.2011.10.014
URL : https://hal.archives-ouvertes.fr/hal-00646982
Existence and Uniqueness for a Linear Mixed Variational Inequality Arising in Electrical Circuits with Transistors, Journal of Optimization Theory and Applications, vol.40, issue.3, pp.397-406, 2008. ,
DOI : 10.1017/S0334270000010912
URL : https://hal.archives-ouvertes.fr/hal-00919738
Stability and Instability Matrices for Linear Evolution Variational Inequalities, IEEE Transactions on Automatic Control, vol.49, issue.4, pp.521-534, 2004. ,
DOI : 10.1109/TAC.2004.825654
URL : http://www.inrialpes.fr/bipop/people/brogliato/IEEE-TAC.2004.pdf
Solving Mathematical Programs with Equilibrium Constraints, Journal of Optimization Theory and Applications, vol.19, issue.1, pp.234-256, 2015. ,
DOI : 10.1080/1055678041001697659
Necessary Optimality Conditions for Optimal Control Problems with Equilibrium Constraints, SIAM Journal on Control and Optimization, vol.54, issue.5, pp.2710-2733, 2016. ,
DOI : 10.1137/15M1013493
URL : http://arxiv.org/pdf/1605.00158
Convergence of Time-Stepping Schemes for Passive and Extended Linear Complementarity Systems, SIAM Journal on Numerical Analysis, vol.47, issue.5, pp.3768-3796, 2009. ,
DOI : 10.1137/080725258
Observer-based control of linear complementarity systems, International Journal of Robust and Nonlinear Control, vol.50, issue.5, pp.1193-1218, 2011. ,
DOI : 10.1016/0024-3795(83)90062-9
URL : https://hal.archives-ouvertes.fr/hal-00834580
Linear Complementarity Systems, SIAM Journal on Applied Mathematics, vol.60, issue.4, pp.1234-1269, 2000. ,
DOI : 10.1137/S0036139997325199
Computation of Steady-State Oscillations in Power Converters Through Complementarity, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.58, issue.6, pp.1421-1432, 2011. ,
DOI : 10.1109/TCSI.2010.2094390
Mathematical Programs with Equilibrium Constraints: Enhanced Fritz John-conditions, New Constraint Qualifications, and Improved Exact Penalty Results, SIAM Journal on Optimization, vol.20, issue.5, pp.2730-2753, 2010. ,
DOI : 10.1137/090774975
A New Regularization Method for Mathematical Programs with Complementarity Constraints with Strong Convergence Properties, SIAM Journal on Optimization, vol.23, issue.2, pp.770-798, 2013. ,
DOI : 10.1137/100802487
On linear dynamic complementary systems, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.46, issue.8, pp.1022-1026, 1999. ,
DOI : 10.1109/81.780383
Interior Methods for Mathematical Programs with Complementarity Constraints, SIAM Journal on Optimization, vol.17, issue.1, pp.52-77, 2006. ,
DOI : 10.1137/040621065
URL : http://www.ece.northwestern.edu/~nocedal/PDFfiles/mpec.pdf
Mathematical Programs with Equilibrium Constraints, 1996. ,
DOI : 10.1017/CBO9780511983658
Solution dependence on initial conditions in differential variational inequalities, Mathematical Programming, vol.81, issue.1-2, pp.429-460, 2009. ,
DOI : 10.1007/978-3-642-02431-3
Optimal Control for Hybrid Systems With Partitioned State Space, IEEE Transactions on Automatic Control, vol.58, issue.8, pp.582131-2136, 2013. ,
DOI : 10.1109/TAC.2013.2246112
Mathematical Programs with Complementarity Constraints: Stationarity, Optimality, and Sensitivity, Mathematics of Operations Research, vol.25, issue.1, pp.1-22, 2000. ,
DOI : 10.1287/moor.25.1.1.15213
A Complementarity Model for Closed-Loop Power Converters, IEEE Transactions on Power Electronics, vol.29, issue.12, pp.6821-6835, 2014. ,
DOI : 10.1109/TPEL.2014.2306975
A complementarity approach for the computation of periodic oscillations in piecewise linear systems, Nonlinear Dynamics, vol.269, issue.5, pp.1255-1273, 2016. ,
On the Hybrid Optimal Control Problem: Theory and Algorithms, IEEE Transactions on Automatic Control, vol.52, issue.9, pp.1587-1603, 2007. ,
DOI : 10.1109/TAC.2007.904451
Robust Non-Zenoness of Piecewise Affine Systems with Applications to Linear Complementarity Systems, SIAM Journal on Optimization, vol.24, issue.4, pp.2023-2056, 2014. ,
DOI : 10.1137/130937068
Linear Complementarity Systems: Zeno States, SIAM Journal on Control and Optimization, vol.44, issue.3, pp.1040-1066, 2005. ,
DOI : 10.1137/040612270
URL : http://www.math.umbc.edu/~shenj/research/sicon_61227.pdf
Stability and observer design for Lur'e systems with multivalued, non-monotone, time-varying nonlinearities and state jumps, SIAM Journal on Control and Optimization, vol.56, issue.2, pp.3639-3672, 2014. ,
DOI : 10.1137/120902252
Well-posedness and output regulation for implicit time-varying evolution variational inequalities, SIAM Journal on Control and Optimization, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01360325
Optimal Control and Applications to Aerospace: Some Results and Challenges, Journal of Optimization Theory and Applications, vol.21, issue.1, pp.713-758, 2012. ,
DOI : 10.1016/0005-1098(85)90107-4
A New Perspective for Modeling Power Electronics Converters: Complementarity Framework, IEEE Transactions on Power Electronics, vol.24, issue.2, pp.456-468, 2009. ,
DOI : 10.1109/TPEL.2008.2007420
Necessary and sufficient optimality conditions for mathematical programs with equilibrium constraints, Journal of Mathematical Analysis and Applications, vol.307, issue.1, pp.350-369, 2005. ,
DOI : 10.1016/j.jmaa.2004.10.032
URL : https://doi.org/10.1016/j.jmaa.2004.10.032
