How to deal with mixed-variable optimization problems: An overview of algorithms and formulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
Real world engineering optimization problems often involve discrete variables (e.g., categorical variables) characterizing choices such as the type of material to be used or the presence of certain system components. From an analytical perspective, these particular variables determine the definition of the objective and constraint functions, as well as the number and type of parameters that characterize the problem. Furthermore, due to the inherent discrete and potentially non-numerical nature of these variables, the concept of metrics is usually not definable within their domain, thus resulting in an unordered set of possible choices. Most modern optimization algorithms were developed with the purpose of solving design problems essentially characterized by integer and continuous variables and by consequence the introduction of these discrete variables raises a number of new challenges. For instance, in case an order can not be defined within the variables domain, it is unfeasible to use optimization algorithms relying on measures of distances, such as Particle Swarm Optimization. Furthermore, their presence results in non-differentiable objective and constraint functions, thus limiting the use of gradient-based optimization techniques. Finally, as previously mentioned, the search space of the problem and the definition of the objective and constraint functions vary dynamically during the optimization process as a function of the discrete variables values. This paper presents a comprehensive survey of the scientific work on the optimization of mixed-variable problems characterized by continuous and discrete variables. The strengths and limitations of the presented methodologies are analyzed and their adequacy for mixed-variable problems with regards to the particular needs of complex system design is discussed, allowing to identify several ways of improvements to be further investigated.
Fichier non déposé
hal-01690446 , version 1 (23-01-2018)
Julien Pelamatti, Loïc Brevault, Mathieu Balesdent, El-Ghazali Talbi, Yannick Guerin. How to deal with mixed-variable optimization problems: An overview of algorithms and formulations. Advances in Structural and Multidisciplinary Optimization, Springer, pp.64-82, 2018, ⟨10.1007/978-3-319-67988-4_5⟩. ⟨hal-01690446⟩
450 Consultations
0 Téléchargements
