Regulation of plant cell wall stiffness by mechanical stress: a mesoscale physical model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
A crucial question in developmental biology is how cell growth is coordinated in living tissue to generate complex and reproducible shapes. We address this issue here in plants, where stiff extracellular walls prevent cell migration and mor-phogenesis mostly results from growth driven by turgor pressure. How cells grow in response to pressure partly depends on the mechanical properties of their walls, which are generally heterogeneous, anisotropic and dynamic. The active control of these properties is therefore a cornerstone of plant morphogenesis. Here, we focus on wall stiffness, which is under the control of both molecular and mechanical signaling. Indeed, in plant tissues, the balance between turgor and cell wall elasticity generates a tissue-wide stress field. Within cells, mechano-sensitive structures, such as cortical microtubules, adapt their behavior accordingly and locally influence cell wall remodeling dynamics. To fully apprehend the properties of this feedback loop, modeling approaches are indispensable. To that end, several modeling tools in the form of virtual tissues have been developed. However , these models often relate mechanical stress and cell wall stiffness in relatively abstract manners, where the molecular specificities of the various actors are not fully captured. In this paper, we propose to refine this approach by including parsimonious biochemical and biomechanical properties of the main molecular actors involved. By a homogenization principle and through finite element simulations, we study the role of stress-sensing microtubules on organ-scale mechanics.
main.pdf (16.9 Mo) Télécharger le fichier
hal-01691110 , version 1 (23-01-2018)
hal-01691110 , version 2 (27-07-2018)
hal-01691110 , version 3 (13-09-2018)
  • HAL Id : hal-01691110 , version 1
Hadrien Oliveri, Jan J. Traas, Christophe Godin, Olivier Ali. Regulation of plant cell wall stiffness by mechanical stress: a mesoscale physical model. 2018. ⟨hal-01691110v1⟩
988 Consultations
537 Téléchargements
