Technical Analysis Techniques versus Mathematical Models: Boundaries of Their Validity Domains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We aim to compare financial technical analysis techniques to strategies which depend on a mathematical model. In this paper, we consider the moving average indicator and an investor using a risky asset whose instantaneous rate of return changes at an unknown random time. We construct mathematical strategies. We compare their performances to technical analysis techniques when the model is misspecified. The comparisons are based on Monte Carlo simulations.
10.1007_3-540-31186-6_2.pdf (358.91 Ko) Télécharger le fichier
hal-01692322 , version 1 (25-01-2018)
  • HAL Id : hal-01692322 , version 1
Christophette Blanchet-Scalliet, Awa Diop, Rajna Gibson, Denis Talay, Etienne Tanré. Technical Analysis Techniques versus Mathematical Models: Boundaries of Their Validity Domains. Monte Carlo and Quasi-Monte Carlo Methods, 2004, Juan les Pins, France. ⟨hal-01692322⟩
270 Consultations
113 Téléchargements
