Constructive Privacy for Shared Genetic Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The need for the sharing of genetic data, for instance, in genome-wide association studies is incessantly growing. In parallel, serious privacy concerns rise from a multi-party access to genetic information. Several techniques , such as encryption, have been proposed as solutions for the privacy-preserving sharing of genomes. However, existing programming means do not support guarantees for privacy properties and the performance optimization of genetic applications involving shared data. We propose two contributions in this context. First, we present new cloud-based architectures for cloud-based genetic applications that are motivated by the needs of geneticians. Second, we propose a model and implementation for the composition of watermarking with encryption, fragmentation, and client-side computations for the secure and privacy-preserving sharing of genetic data in the cloud.
closer18.pdf (236.75 Ko) Télécharger le fichier
hal-01692620 , version 1 (25-01-2018)
hal-01692620 , version 2 (06-02-2018)
Fatima-Zahra Boujdad, Mario Südholt. Constructive Privacy for Shared Genetic Data. CLOSER 2018 : 8th International Conference on Cloud Computing and Services Science, Mar 2018, Funchal, Madeira, Portugal. pp.1-8, ⟨10.5220/0006765804890496⟩. ⟨hal-01692620v2⟩
928 Consultations
276 Téléchargements
