On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia vuzov. Mathematica, vol.1, pp.80-88, 1958. ,
On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia vuzov. Mathematica, vol.3, issue.22, pp.157-164, 1961. ,
Stability of Motion, 1967. ,
DOI : 10.1007/978-3-642-50085-5
Nilpotent Approximations of Control Systems and Distributions, SIAM Journal on Control and Optimization, vol.24, issue.4, p.731, 1986. ,
DOI : 10.1137/0324045
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, issue.6, pp.467-473, 1992. ,
DOI : 10.1016/0167-6911(92)90078-7
Geometric homogeneity and stabilization, Proc. IFAC Nonlinear Control Symposium, pp.164-169, 1995. ,
DOI : 10.1016/s1474-6670(17)46822-4
Methods of A.M. Lyapunov and Their Applications, 1964. ,
Lyapunov Functions and Stability in Control Theory, 2001. ,
Adding an integrator for the stabilization problem, Systems & Control Letters, vol.17, issue.2, pp.89-104, 1991. ,
DOI : 10.1016/0167-6911(91)90034-C
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals, and Systems, vol.17, issue.2, pp.101-127, 2005. ,
DOI : 10.1007/s00498-005-0151-x
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
DOI : 10.1016/j.automatica.2004.11.029
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, issue.1, pp.332-340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
High gain observers with updated gain and homogeneous correction terms, Automatica, vol.45, issue.2, pp.422-428, 2009. ,
DOI : 10.1016/j.automatica.2008.07.015
URL : https://hal.archives-ouvertes.fr/hal-00362752
Finite-time and fixed-time observers design via implicit Lyapunov function, 2016 European Control Conference (ECC), 2016. ,
DOI : 10.1109/ECC.2016.7810300
URL : https://hal.archives-ouvertes.fr/hal-01298162
Universal stabilization of a class of nonlinear systems with homogeneous vector fields, Systems & Control Letters, vol.26, issue.3, pp.177-184, 1995. ,
DOI : 10.1016/0167-6911(95)00013-Y
H??? control, stabilization, and input???output stability of nonlinear systems with homogeneous properties, Automatica, vol.37, issue.6, pp.819-829, 2001. ,
DOI : 10.1016/S0005-1098(01)00027-9
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, issue.12, pp.1159-1167, 2013. ,
DOI : 10.1016/j.sysconle.2013.09.004
URL : https://hal.archives-ouvertes.fr/hal-00877148
On Homogeneous Distributed Parameter Systems, IEEE Transactions on Automatic Control, vol.61, issue.11, pp.3657-3662, 2016. ,
DOI : 10.1109/TAC.2016.2525925
URL : https://hal.archives-ouvertes.fr/hal-01318134
Method of Controlability Functions (in Russian), NIC, 2007. ,
Finite-Time Stabilization of $2\times2$ Hyperbolic Systems on Tree-Shaped Networks, SIAM Journal on Control and Optimization, vol.52, issue.1, pp.143-163, 2014. ,
DOI : 10.1137/130910762
Stabilization and controllability of first-order integro-differential hyperbolic equations, Journal of Functional Analysis, vol.271, issue.12, pp.3554-3587, 2016. ,
DOI : 10.1016/j.jfa.2016.08.018
URL : https://hal.archives-ouvertes.fr/hal-01224012
Null controllability and finite time stabilization for the heat equations with variable coefficients in space in one dimension via backstepping approach Archive for Rational Mechanics and Analysis, pp.2017-2027 ,
Finite-time backstepping boundary stabilization of 3x3 hyperbolic systems, European Control Conference (ECC), pp.67-73, 2015. ,
Observation and Control for Operator Semigroups, 2009. ,
DOI : 10.1007/978-3-7643-8994-9
URL : https://hal.archives-ouvertes.fr/hal-00590673
Application of Lyapunov method in distributed systems, Automation and Remote Control, vol.44, pp.426-430, 1983. ,
Tracking Control of the Uncertain Heat and Wave Equation via Power-Fractional and Sliding-Mode Techniques, SIAM Journal on Control and Optimization, vol.49, issue.2, pp.363-382, 2011. ,
DOI : 10.1137/090781140
A general approach to synthesis problem, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.42, issue.10, pp.69-90, 2016. ,
DOI : 10.1201/9781420065619
URL : https://hal.archives-ouvertes.fr/hal-01160052
On finite-time stabilization of evolution equations: A homogeneous approach, 2016 IEEE 55th Conference on Decision and Control (CDC), pp.3143-3148, 2016. ,
DOI : 10.1109/CDC.2016.7798740
URL : https://hal.archives-ouvertes.fr/hal-01371089
Semigroups of Linear Operators and Applications to Partial Differential Equations, 1983. ,
DOI : 10.1007/978-1-4612-5561-1
Oscillations Conditions in Homogenous Systems, Proc. IFAC NOLCOS Symp, pp.1379-1384, 2010. ,
DOI : 10.3182/20100901-3-IT-2016.00101
URL : https://hal.archives-ouvertes.fr/hal-00561003
Boundary finite-time feedback design for heat equation, IFAC World Congress, 2017. ,
DOI : 10.1016/j.ifacol.2017.08.116
URL : https://hal.inria.fr/hal-01505482/document
Boundary Control of PDEs: A Course on Backstepping Designs, 2008. ,
DOI : 10.1137/1.9780898718607
Implicit Functions and Optimization Problems without Continuous Differentiability of the Data, SIAM Journal on Control, vol.12, issue.2, 1974. ,
DOI : 10.1137/0312017
