Fast Power system security analysis with Guided Dropout - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We propose a new method to efficiently compute load-flows (the steady-state of the power-grid for given productions, consumptions and grid topology), substituting conventional simulators based on differential equation solvers. We use a deep feed-forward neural network trained with load-flows precomputed by simulation. Our architecture permits to train a network on so-called " n-1 " problems, in which load flows are evaluated for every possible line disconnection, then generalize to " n-2 " problems without retraining (a clear advantage because of the combinatorial nature of the problem). To that end, we developed a technique bearing similarity with " dropout " , which we named " guided dropout ".
main.pdf (693.63 Ko) Télécharger le fichier
hal-01695793 , version 1 (29-01-2018)
Benjamin Donnot, Isabelle Guyon, Marc Schoenauer, Antoine Marot, Patrick Panciatici. Fast Power system security analysis with Guided Dropout. 26th European Symposium on Artificial Neural Networks, Apr 2018, Bruges, Belgium. ⟨hal-01695793⟩
542 Consultations
263 Téléchargements
