Automatic guide-wire detection for neurointerventions using low-rank sparse matrix decomposition and denoising - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Markus Zweng
  • Fonction : Auteur
Pascal Fallavolita
  • Fonction : Auteur
Stefanie Demirci
  • Fonction : Auteur
Markus Kowarschik
  • Fonction : Auteur
In neuro-interventional surgeries, physicians rely on fluoro-scopic video sequences to guide tools through the vascular system to the region of interest. Due to the low signal-to-noise ratio of low-dose images and the presence of many line-like structures in the brain, the guide-wire and other tools are difficult to see. In this work we propose an effective method to detect guide-wires in fluoroscopic videos that aims at enhancing the visualization for better intervention guidance. In contrast to prior work, we do not rely on a specific modeling of the catheter (e.g. shape, intensity, etc.), nor on prior statistical learning. Instead, we base our approach on motion cues by making use of recent advances in low-rank and sparse matrix decomposition, which we then combine with denoising. An evaluation on 651 X-ray images from 5 patient shows that our guide-wire tip detection is precise and within clinical tolerance for guide-wire inter-frame motions as high as 6mm.
Fichier non déposé
hal-01695947 , version 1 (29-01-2018)
  • HAL Id : hal-01695947 , version 1
Markus Zweng, Pascal Fallavolita, Stefanie Demirci, Markus Kowarschik, Nassir Navab, et al.. Automatic guide-wire detection for neurointerventions using low-rank sparse matrix decomposition and denoising. AE-CAI Workshop at the International Conference on Medical Image Computing and Computer Aided Interventions, Oct 2015, Munich, Germany. ⟨hal-01695947⟩
82 Consultations
0 Téléchargements
