On tide propagation in convergent estuaries ,
, Geophys. Res, vol.103, pp.30793-30812, 1998.
Relevant parameters and finite am602 plitude effects in estuarine hydrodynamics, J. Geophys. Res, vol.111, 2006. ,
Tidal bore dy605 namics in funnel-shaped estuaries, J. Geophys. Res, vol.120, 2015. ,
Nonlinear barotropic tides and bores in estu608 aries, Tellus, vol.43, pp.246-256, 1991. ,
Linking the river to the estuary: 610 influence of river discharge on tidal damping, Hydrol. Earth Syst. Sci, vol.18, pp.287-304, 2014. ,
Salinity and tides in alluvial estuaries, 2012. ,
Calculations of the development of an undular bore ,
Long waves in a straight channel with non-uniform 641 cross-section, J.Fluid Mech, vol.770, pp.156-188, 2015. ,
A splitting 643 approach for the fully nonlinear and weakly dispersive Green-Naghdi model, p.644 ,
, J.Comp.Phys, vol.230, issue.4, pp.1479-1498, 2011.
A flexible genuinely non646 linear approach for nonlinear wave propagation, breaking and run-up, p.647 ,
, J.Comp.Phys, vol.310, p.381417, 2016.
Hydrodynamics and morphodynamics of tidal channels, 2002. ,
, Wave Model Documentation and User's Manual, 1998.
Generation of waves in Boussinesq models 654 using a source function method, Coast.Eng, vol.36, pp.271-299, 1999. ,
A numerical method for extended Boussinesq shallow-water 656 wave equations, 1999. ,
, , p.658
, Generating-absorbing sponge layers for phase-resolving wave models, p.659
, Coast.Eng, vol.84, pp.1-9, 2014.
A fourth-order com661 pact finite volume scheme for fully nonlinear and weakly dispersive 662 ,
, Boussinesq-type equations. part II: Boundary conditions and validation, p.663
, Int.J.Numer.Meth.Fluids, vol.53, pp.1423-1455, 2007.
The sediment trapping efficiency of 665 the macro-tidal Daly Estuary, tropical Australia, Estuarine, Coastal and 666 Shelf Science, vol.69, pp.291-298, 2006. ,
, , p.668
, Man-induced regime shifts in small estuaries II: a comparison of rivers, p.669
, Ocean Dynamics, vol.63, pp.1293-1306, 2013.
Relation between tidal damp671 ing and wave celerity in estuaries, J. Geophys. Res, vol.101, p.672, 2005. ,
A simple analytical expression to describe tidal damping 674 or amplification, J. Hydrol, vol.243, pp.205-215, 2001. ,
Non-linear frictional residual effects 676 on tide propagation, Proceedings of XXX IAHR Congress, pp.291-298, 2003. ,
, Tidal Bores, Aegir, Aegir, Eagre, Mascaret, Pororoca: Theory 678 and Observations, 2012.
