Lathe Machining in the Era of Industry 4.0: Remanufactured Lathe with Integrated Measurement System for CNC Generation of the Rolling Surfaces for Railway Wheels
Abstract : Many projects and researches in the field of remanufacturing of specialized lathes are presented in the specialized literature. In the process of design for remanufacturing, a great number of solutions contain different aspects and data important to consider. The paper presents important stages of theoretical and applied research regarding the modernization of a conventional lathe with two working units by adaptation of four driving chains for CNC advance/positioning movements and improvements of translation couplings, adaptation of CNC equipment for driving and measuring simultaneous both wheels mounted on axle. The reducing of geometrical errors of the running profile is very important in reshaping the worn wheelsets. The lathe remanufacturing process involves the restoration of functional requirements and measurement of the geometric precision. The CNC capabilities of the remanufactured lathe require a database of parametric representation of profiles and rolling surfaces using CAD techniques according to international standards.
https://hal.inria.fr/hal-01699693 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, February 2, 2018 - 4:03:13 PM Last modification on : Friday, February 2, 2018 - 4:28:16 PM Long-term archiving on: : Thursday, May 3, 2018 - 12:45:06 AM
Ionuţ Ghionea, Adrian Ghionea, Daniela Cioboată, Saša Ćuković. Lathe Machining in the Era of Industry 4.0: Remanufactured Lathe with Integrated Measurement System for CNC Generation of the Rolling Surfaces for Railway Wheels. 13th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2016, Columbia, SC, United States. pp.296-308, ⟨10.1007/978-3-319-54660-5_27⟩. ⟨hal-01699693⟩
