User Behavior-Aware Channel Allocation Scheme for Mobile Ad hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article presents a user behavior aware channel allocation scheme for mobile ad hoc networks. The proposed scheme uses a distributed approach to dynamically allocate the IEEE 802.11b/g spectrum. Our main contribution is to consider the user behavior, represented by the mobility, traffic, and node degree to guide the channel allocation process. In addition, we use a mobility model based on the social context found in people sharing common interests. The results show that our strategy presents throughput 15,43% and 17,74% higher when compared with RANDOM and LD algorithms, respectively.
Fichier non déposé
hal-01700131 , version 1 (03-02-2018)
Roni F Shigueta, Mauro Fonseca, Aline Carneiro Viana. User Behavior-Aware Channel Allocation Scheme for Mobile Ad hoc Networks. IPCCC 2016 - IEEE 35th International Performance Computingand Communications Conference, Dec 2016, Las Vegas, United States. ⟨10.1109/PCCC.2016.7820598⟩. ⟨hal-01700131⟩
92 Consultations
0 Téléchargements
