Gradient-based dimension reduction of multivariate vector-valued functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We propose a gradient-based method for detecting and exploiting low-dimensional input parameter dependence of multivariate functions. The methodology consists in minimizing an upper bound, obtained by Poincaré-type inequalities, on the approximation error. The resulting method can be used to approximate vector-valued functions (e.g., functions taking values in $\mathbb{R}^n$ or functions taking values in function spaces) and generalizes the notion of active subspaces associated with scalar-valued functions. A comparison with the truncated Karhunen-Loève decomposition shows that using gradients of the function can yield more effective dimension reduction. Numerical examples reveal that the choice of norm on the codomain of the function can have a significant impact on the function's low-dimensional approximation.
2018-10 Gradient-based dimension reduction of multivariate vector-valued functions.pdf (2.83 Mo) Télécharger le fichier
hal-01701425 , version 1 (05-02-2018)
hal-01701425 , version 2 (14-12-2018)
hal-01701425 , version 3 (08-11-2019)
Olivier Zahm, Paul Constantine, Clémentine Prieur, Youssef Marzouk. Gradient-based dimension reduction of multivariate vector-valued functions. 2018. ⟨hal-01701425v2⟩
572 Consultations
784 Téléchargements
