New interface
Journal articles
Gradient-based dimension reduction of multivariate vector-valued functions
Olivier Zahm 1 Paul Constantine 2 Clémentine Prieur 1 Youssef Marzouk 3
1 AIRSEA - Mathematics and computing applied to oceanic and atmospheric flows
Inria Grenoble - Rhône-Alpes, UGA - Université Grenoble Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : Multivariate functions encountered in high-dimensional uncertainty quantification problems often vary along a few dominant directions in the input parameter space. We propose a gradient-based method for detecting these directions and using them to construct ridge approximations of such functions, in a setting where the functions are vector-valued (e.g., taking values in Rn). The methodology consists of minimizing an upper bound on the approximation error, obtained by subspace Poincaré inequalities. We provide a thorough mathematical analysis in the case where the parameter space is equipped with a Gaussian probability measure. The resulting method generalizes the notion of active subspaces associated with scalar-valued functions. A numerical illustration shows that using gradients of the function yields effective dimension reduction. We also show how the choice of norm on the codomain of the function has an impact on the function's low-dimensional approximation.
Document type :
Journal articles
Complete list of metadata
Cited literature [56 references]  Display  Hide  Download
https://hal.inria.fr/hal-01701425
Contributor : Olivier Zahm Connect in order to contact the contributor
Submitted on : Friday, November 8, 2019 - 10:43:09 AM
Last modification on : Friday, November 18, 2022 - 9:23:06 AM
Long-term archiving on: : Sunday, February 9, 2020 - 9:41:35 PM
File
main.pdf
Identifiers
Collections
Citation
Olivier Zahm, Paul Constantine, Clémentine Prieur, Youssef Marzouk. Gradient-based dimension reduction of multivariate vector-valued functions. SIAM Journal on Scientific Computing, 2020, 42 (1), pp.A929-A956. ⟨10.1137/18M1221837⟩. ⟨hal-01701425v3⟩
Share
Metrics
Record views
542
Files downloads
674
