Toward software updates in IoT environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The number of connected devices around us is growing, and their embedded software is increasing in complexity. Applications need to be managed and updated throughout their life-cycle. Modern software orchestrators and management systems are mostly cen-tralised and expensive to scale to very large systems. We propose a decentralised approach to distribute software updates to Internet of Things (IoT) devices using Peer-to-Peer (P2P) transfers. We seek to improve the efficiency of software update propagation by adapting system behaviour to IoT constraints, such as device heterogeneity, unreliable network connectivity and applications specifics.
a6-trystram.pdf (344.81 Ko) Télécharger le fichier
hal-01702543 , version 1 (06-02-2018)
Jean-Baptiste Trystram. Toward software updates in IoT environments: Why Existing P2P Systems are not Enough. 18th Doctoral Symposium of the 18th International Middleware Conference, Dec 2017, Las Vegas, United States. ⟨10.1145/3152688.3152694⟩. ⟨hal-01702543⟩
244 Consultations
216 Téléchargements
