Electronic “Pockets of Effectiveness”: E-governance and Institutional Change in St. Petersburg, Russia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper explores the patterns and factors of e-governance development in ineffective institutional settings. Although it is assumed that most of e-projects in such countries failed, we argue that in some contexts such initiatives can survive in the hostile environment and achieve relatively positive results, leading to limited institutional changes. We adapt the pockets of effectiveness framework in order to analyze the Our Petersburg portal (St. Petersburg, Russia). Our findings suggest that such electronic “pockets” may emerge as a deliberate policy of the political elite in an attempt to make institutions work properly. The key factors of such projects’ success relate to agency, namely the political patronage and control, policy entrepreneurship, as well as organization autonomy and the power of the initiative.
453552_1_En_32_Chapter.pdf (340.65 Ko) Télécharger le fichier
hal-01702998 , version 1 (07-02-2018)
Paternité
Yury Kabanov, Andrei V. Chugunov. Electronic “Pockets of Effectiveness”: E-governance and Institutional Change in St. Petersburg, Russia. 16th International Conference on Electronic Government (EGOV), Sep 2017, St. Petersburg, Russia. pp.386-398, ⟨10.1007/978-3-319-64677-0_32⟩. ⟨hal-01702998⟩
77 Consultations
203 Téléchargements
