Robust discrete optimization and network flows, Math. Program, vol.98, issue.1-3, pp.49-71, 2003. ,
An adaptive memory programming framework for the robust capacitated vehicle routing problem, Transportation Science, vol.50, issue.4, pp.1239-1260, 2016. ,
The robust capacitated vehicle routing problem under demand uncertainty, Operations Research, vol.61, issue.3, pp.677-693, 2013. ,
A short note on the robust combinatorial optimization problems with cardinality constrained uncertainty, vol.4, pp.373-378, 2014. ,
Improved branch-cut-and-price for capacitated vehicle routing, Math. Prog. Computation, vol.9, issue.1, pp.61-100, 2017. ,
Robust combinatorial optimization with knapsack uncertainty. Discrete Optimization ,
URL : https://hal.archives-ouvertes.fr/hal-01444717
A bucket graph based labeling algorithm with application to vehicle routing, Cadernos do LOGIS 2017/7, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01664854
