Sprinkler: A probabilistic dissemination protocol to provide fluid user interaction in multi-device ecosystems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Offering fluid multi-device interactions to users while protecting their privacy largely remains an ongoing challenge. Existing approaches typically use a peer-to-peer design and flood session information over the network, resulting in costly and often unpractical solutions. In this paper, we propose Sprinkler, a decentralized probabilistic dissemination protocol that uses a gossip-based learning algorithm to intelligently propagate session information to devices a user is most likely to use next. Our solution allows designers to efficiently trade off network costs for fluidity, and is for instance able to reduce network costs by up to 80% against a flooding strategy while maintaining a fluid user experience.
sprinkler_percom2018.pdf (2.07 Mo) Télécharger le fichier
hal-01704172 , version 1 (08-02-2018)
hal-01704172 , version 2 (22-05-2018)
Adrien Luxey, Yérom-David Bromberg, Fábio M Costa, Vinícius Lima, Ricardo da Rocha, et al.. Sprinkler: A probabilistic dissemination protocol to provide fluid user interaction in multi-device ecosystems. PerCom 2018 - IEEE International Conference on Pervasive Computing and Communications, Mar 2018, Athens, Greece. pp.1-10, ⟨10.1109/PERCOM.2018.8444577⟩. ⟨hal-01704172v2⟩
618 Consultations
267 Téléchargements
