New interface
Conference papers
TCon: A Transparent Congestion Control Deployment Platform for Optimizing WAN Transfers
Abstract : Nowadays, many web services (e.g., cloud storage) are deployed inside datacenters and may trigger transfers to clients through WAN. TCP congestion control is a vital component for improving the performance (e.g., latency) of these services. Considering complex networking environment, the default congestion control algorithms on servers may not always be the most efficient, and new advanced algorithms will be proposed. However, adjusting congestion control algorithm usually requires modification of TCP stacks of servers, which is difficult if not impossible, especially considering different operating systems and configurations on servers. In this paper, we propose TCon, a light-weight, flexible and scalable platform that allows administrators (or operators) to deploy any appropriate congestion control algorithms transparently without making any changes to TCP stacks of servers. We have implemented TCon in Open vSwitch (OVS) and conducted extensive test-bed experiments by transparently deploying BBR congestion control algorithm over TCon. Test-bed results show that the BBR over TCon works effectively and the performance stays close to its native implementation on servers, reducing latency by 12.76% on average.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01705451
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, February 9, 2018 - 2:26:55 PM
Last modification on : Friday, May 29, 2020 - 9:58:04 AM
File
457609_1_En_5_Chapter.pdf
Identifiers
Citation
Yuxiang Zhang, Lin Cui, Fung Po Tso, Quanlong Guan, Weijia Jia. TCon: A Transparent Congestion Control Deployment Platform for Optimizing WAN Transfers. 14th IFIP International Conference on Network and Parallel Computing (NPC), Oct 2017, Hefei, China. pp.49-61, ⟨10.1007/978-3-319-68210-5_5⟩. ⟨hal-01705451⟩
Share
Metrics
Record views
135
Files downloads
66
