Abstract :
Aiming at the problem that the bandwidth allocation method in heterogeneous data center can’t take into account the global and local fairness, we propose an allocation method called GLA that satisfies fair attributes and can improve the utilization of system resources by nearly 20% when the number of clients are more than six contrasting with the existing methods. The algorithm is also protable and scalable that can adapt to most of systems.
https://hal.inria.fr/hal-01705453 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, February 9, 2018 - 2:27:04 PM Last modification on : Wednesday, November 3, 2021 - 4:18:56 AM Long-term archiving on: : Friday, May 4, 2018 - 12:44:52 AM
Bingyu Zhou, Guangjun Qin, Limin Xiao, Zhisheng Huo, Bing Wei, et al.. Balancing Global and Local Fairness Allocation Model in Heterogeneous Data Center. 14th IFIP International Conference on Network and Parallel Computing (NPC), Oct 2017, Hefei, China. pp.136-139, ⟨10.1007/978-3-319-68210-5_15⟩. ⟨hal-01705453⟩
