Conference papers
A Robust Facility Layout Planning Method Considering Temporal Efficiency
Abstract : Facility layout planning (FLP) is an important stage for optimal design of manufacturing systems. A major approach is to define an evaluation index based on distance and find a layout which minimizes it. Temporal efficiency is not considered in this stage but in later stages. The resultant temporal efficiency may not be optimal enough, since decision and optimization in those stages are performed under the fixed layout. For this reason, the authors have developed FLP methods considering temporal efficiency. Those methods provide the optimal layout plan for a fixed production scenario. However, production environments change dynamically in actual manufacturing, and the layout plan is no longer optimal after the changes. In this paper, the conventional method is enhanced considering robustness against the changes.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01707270
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, February 12, 2018 - 4:25:36 PM
Last modification on : Monday, January 3, 2022 - 4:36:02 PM
Long-term archiving on: : Monday, May 7, 2018 - 6:05:53 PM
File
456373_1_En_20_Chapter.pdf
Identifiers
Citation
Eiji Morinaga, Komei Iwasaki, Hidefumi Wakamatsu, Eiji Arai. A Robust Facility Layout Planning Method Considering Temporal Efficiency. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.168-175, ⟨10.1007/978-3-319-66926-7_20⟩. ⟨hal-01707270⟩
Share
Metrics
Record views
67
Files downloads
61
