New interface
Conference papers
Multiresolution Analysis with Non-Nested Spaces
Georges-Pierre Bonneau 1
1 iMAGIS - Models, Algorithms and Geometry for Computer Generated Image Graphics
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes
Abstract : Two multiresolution analyses (MRA) intended to be used in scientiic visualization, and that are both based on a non-nested set of approximating spaces, are presented. The notion of approximated r eenement is introduced to deal with non nested spaces. The rst MRA scheme, referred to as BLaC (Blending of Linear and Constant) wavelets is based on a one parameter family of wavelet bases that realizes a blend between the Haar and the linear wavelet bases. The approximated reenement is applied in the last part to build a second MRA scheme for data deened on an arbitrary planar triangular mesh.
Document type :
Conference papers
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-01708577
Contributor : Georges-Pierre Bonneau Connect in order to contact the contributor
Submitted on : Tuesday, February 13, 2018 - 6:32:19 PM
Last modification on : Tuesday, May 3, 2022 - 4:44:02 PM
Long-term archiving on: : Saturday, May 5, 2018 - 7:40:51 PM
File
bonneau_dag96.pdf
Identifiers
  • HAL Id : hal-01708577, version 1
Collections
Citation
Georges-Pierre Bonneau. Multiresolution Analysis with Non-Nested Spaces. Dagstuhl seminar on Visualization, 1996, Dagstuhl, Germany. pp.51-66. ⟨hal-01708577⟩
Share
Metrics
Record views
48
Files downloads
58
