BLAC-wavelets: a m ultiresolution analysis with non-nested spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
In the last five years, there has been numerous applications of wavelets and multires-olution analysis in many elds of computer graphics as diierent as geometric modelling, volume visualization or illumination modelling. Classical multiresolution analysis is based on the knowledge of a nested set of functional spaces in which the successive approximations of a given function converge to that function, and can be eeciently computed. This paper rst proposes a theoretical framework which enables multiresolution analysis even if the functional spaces are not nested, as long as they still have the property that the successive approximations converge to the given function. Based on this concept we nally introduce a new multiresolution analysis with exact reconstruction for large data sets deened on uniform grids. We construct a one-parameter family of multiresolution analyses which is a blending of Haar and linear multiresolution.
BHN-VIS96.pdf (1.35 Mo) Télécharger le fichier
hal-01708581 , version 1 (13-02-2018)
Georges-Pierre Bonneau, Stefanie Hahmann, Gregory M Nielson. BLAC-wavelets: a m ultiresolution analysis with non-nested spaces. VIS 1996 - 7th Annual IEEE Visualization '96, Oct 1996, San Francisco, United States. pp.1-6, ⟨10.1109/VISUAL.1996.567602⟩. ⟨hal-01708581⟩
114 Consultations
129 Téléchargements
