Bézier Representation of Trim Curves
The composition of Bezier curves and tensor product Bezier surfaces,
polynomial as well as rational, is applied to exactly and explicitely represent trim
curves of tensor product Bezier surfaces. Trimming curves are assumed to be defined
as Bezier curves in surface parameter domain. A Bezier spline approximation of
lower polynomial degree is built up as well which is based on the exact trim curve
representation in coordinate space.
