Patrikalakis: Blending rational B-spline surfaces. EURO- GRAPHICS, pp.453-462, 1989. ,
Casale : Free-form solid modeling with trimmed surface patches, IEEE Computer Graphics & Applications, vol.7, pp.33-43, 1987. ,
Bobrow: A set operation algor!thm for sculptured solids modeled with trimmed patches Trimmed-patch boundary elements: bridging the gap between solid modeling and engineering analysis, Cas 92), pp.235-248, 1989. ,
Ju: Constant-radius blending in surface modelling Boundary evaluation of non-convex primitives to produce parametric trimmed surfaces, SIGGRA.PH '87, pp.129-136, 1987. ,
Composing Bezier simplices, ACM Transactions on Graphics, vol.7, pp.198-221, 1988. ,
Functional composition algorithms via blossoming 113-135. [Elb 92) G. Elber: Free form surface analysis using a hybrid of symbolic and numeric computation (Far 90) G. Farin: Curves and surfaces for computer aided geometric design. A practical guide, ACM Transactions on Graphics, vol.12, issue.2, 1990. ,
Farouki: Trimmed-surface algorithms for the evaluation and interrogation of solid boundary representations, IBM Journal of Research and Development, vol.31, pp.314-334, 1987. ,
On the stability of transformations between power and Bernstein polynomial forms [Fil 89) D.J. Filip: Blending parametric surfaces, Computer Aided Geometrie Design ACM Transactions on Graphics, vol.8, issue.8, pp.29-36, 1989. ,
Chiyokura : An enhanced rounding operation between curved surfaces in solid modeling, CG International '90, pp.563-588, 1990. ,
Optimal approximate conversion of spline surfaces, Computer Aided Geometric Design, vol.6, issue.4, pp.293-306, 1989. ,
DOI : 10.1016/0167-8396(89)90030-7
Spline conversion for trimmed rational B??zier- and B-spline surfaces, Computer-Aided Design, vol.22, issue.9, pp.580-590, 1990. ,
DOI : 10.1016/0010-4485(90)90043-C
Fillet and surface intersections defined by rolling balls, Computer Aided Geometric Design, vol.9, issue.3, pp.185-193, 1992. ,
DOI : 10.1016/0167-8396(92)90016-I
Polygonal subdivision of parametric surfaces Advanced computer graphics, pp.50-59, 1986. ,
Composition of Tensor Product B??zier Representations, Interner Bericht, vol.21391, 1991. ,
DOI : 10.1007/978-3-7091-6916-2_11
Sculptured Surfaces in Solid Models: Issues and Alternative Approaches, IEEE Computer Graphics and Applications, vol.6, issue.12, pp.37-48, 1986. ,
DOI : 10.1109/MCG.1986.276588
Ray tracing trimmed rational surface patches, ACM SIGGRAPH Computer Graphics, vol.24, issue.4, pp.337-345, 1990. ,
DOI : 10.1145/97880.97916
Real time rendering of trimmed surfaces, ACM Computer Graphics, vol.89, issue.23, pp.107-116, 1989. ,
Designing and mapping trimming curves on surfaces using orthogonal projection, Advances in Design Automation, vol.1, pp.235-245, 1990. ,
Rendering trimmed NURBS with adaptive forward differencing, ACM Computer Graphics, vol.88, issue.22, pp.189-198, 1988. ,
DOI : 10.1145/54852.378510
Triangulation of trimmed surfaces in parametric space, Computer-Aided Design, vol.24, issue.8, pp.437-444, 1992. ,
DOI : 10.1016/0010-4485(92)90011-X
Exact conversion of a trimmed nonrational Bezier surface into composite or basic nonrational Bezier surfaces Topics in surface modeling, Siam, pp.115-143, 1992. ,
