A semiparametric multivariate and multisite weather generator, Water Resources Research, vol.34, issue.1, p.11401, 2007. ,
DOI : 10.1080/02626668909491307
URL : http://onlinelibrary.wiley.com/doi/10.1029/2006WR005714/pdf
Application of Bernstein Polynomials for smooth estimation of a distribution and density function, Journal of Statistical Planning and Inference, vol.105, issue.2, pp.377-392, 2002. ,
DOI : 10.1016/S0378-3758(01)00265-8
Démonstration du théorème de Weierstrass fondée sur le calcul des probabilités, Communications de la Société mathématique de Kharkow, vol.13, issue.1, pp.1-2, 1912. ,
Bernstein estimator for unbounded density function, Journal of Nonparametric Statistics, vol.9, issue.3, pp.145-161, 2007. ,
DOI : 10.1007/978-1-4899-3324-9
A hybrid Pareto model for asymmetric fat-tailed data: the univariate case, Extremes, vol.15, issue.1, pp.53-76, 2008. ,
DOI : 10.1007/978-3-642-33483-2
Partitioning into hazard subregions for regional peaks-over-threshold modeling of heavy precipitation, Water Resources Research, vol.26, issue.3, pp.4407-4426, 2017. ,
DOI : 10.1029/2006WR005095
An introduction to statistical modeling of extreme values, 2001. ,
DOI : 10.1007/978-1-4471-3675-0
Modelling Excesses over High Thresholds, with an Application, Statistical Extremes and Applications, pp.461-482, 1984. ,
DOI : 10.1007/978-94-017-3069-3_34
A regional model for extreme rainfall based on weather patterns subsampling, Journal of Hydrology, vol.541, pp.1185-1198, 2016. ,
DOI : 10.1016/j.jhydrol.2016.08.024
Stochastic generation of multi-site daily precipitation focusing on extreme events, Hydrology and Earth System Sciences, vol.22, issue.1, pp.655-672, 2018. ,
DOI : 10.1029/2002WR001769
The Bernstein polynomial basis: A centennial retrospective, Computer Aided Geometric Design, vol.29, issue.6, pp.379-419 ,
DOI : 10.1016/j.cagd.2012.03.001
Improving the simulation of extreme precipitation events by stochastic weather generators, Water Resources Research, vol.83, issue.3, p.12439, 2008. ,
DOI : 10.1007/s00704-005-0156-x
Introducing a rainfall compound distribution model based on weather patterns sub-sampling, Hydrology and Earth System Sciences, vol.14, issue.6, pp.951-964, 2010. ,
DOI : 10.5194/hess-14-951-2010
URL : https://hal.archives-ouvertes.fr/hal-00494939
polynomials, The Annals of Statistics, vol.29, issue.5, pp.1264-1280, 2001. ,
DOI : 10.1214/aos/1013203453
Computing Maximum Likelihood Estimates for the Generalized Pareto Distribution, Technometrics, vol.4, issue.2, pp.185-191, 1993. ,
DOI : 10.1214/ss/1177012400
Use of models in detection and attribution of climate change, Wiley interdisciplinary reviews: climate change, pp.570-591, 2011. ,
DOI : 10.1038/453296a
Applications of beta-mixture models in bioinformatics, Bioinformatics, vol.6, issue.7, pp.2118-2122, 2005. ,
DOI : 10.1214/aos/1176344136
Bernstein polynomial probability density estimation, Journal of Nonparametric Statistics, vol.2, issue.5, pp.709-729, 2004. ,
DOI : 10.1007/BF02056918
Precipitation as a Chain-Dependent Process, Journal of Applied Meteorology, vol.16, issue.7, pp.671-676, 1977. ,
DOI : 10.1175/1520-0450(1977)016<0671:PAACDP>2.0.CO;2
URL : http://journals.ametsoc.org/doi/pdf/10.1175/1520-0450%281977%29016%3C0671%3APAACDP%3E2.0.CO%3B2
Statistics of extremes in hydrology, Advances in Water Resources, vol.25, issue.8-12, pp.1287-1304, 2002. ,
DOI : 10.1016/S0309-1708(02)00056-8
A bias-reduced approach to density estimation using Bernstein polynomials, Journal of Nonparametric Statistics, vol.2, issue.4, pp.459-475, 2010. ,
DOI : 10.1007/978-1-4899-4493-1
On estimating distribution functions using Bernstein polynomials, Annals of the Institute of Statistical Mathematics, vol.26, issue.5, pp.919-943 ,
DOI : 10.1016/B978-0-12-568002-8.50011-2
On the boundary properties of Bernstein polynomial estimators of density and distribution functions, Journal of Statistical Planning and Inference, vol.142, issue.10, pp.2762-2778 ,
DOI : 10.1016/j.jspi.2012.03.016
A flexible extreme value mixture model, Computational Statistics & Data Analysis, vol.55, issue.6, pp.2137-2157, 2011. ,
DOI : 10.1016/j.csda.2011.01.005
The EM algorithm and extensions, 2007. ,
Extremes of Daily Rainfall in West Central Florida, Climatic Change, vol.22, issue.2-3, pp.325-342, 2005. ,
DOI : 10.1007/s10584-005-1812-y
Modeling jointly low, moderate, and heavy rainfall intensities without a threshold selection, Water Resources Research, vol.34, issue.3, pp.2753-2769, 2016. ,
DOI : 10.3354/cr00696
URL : http://repository.kaust.edu.sa/kaust/bitstream/10754/608588/1/Naveau_et_al-2016-Water_Resources_Research.pdf
Bayesian density estimation using bernstein polynomials, Canadian Journal of Statistics, vol.2, issue.3, pp.105-126, 1999. ,
A note of caution when interpreting parameters of the distribution of excesses, Advances in Water Resources, vol.34, issue.10, pp.1215-1221, 2011. ,
DOI : 10.1016/j.advwatres.2011.05.003
Stochastic simulation of daily precipitation, temperature, and solar radiation, Water Resources Research, vol.8, issue.1, pp.182-190, 1981. ,
DOI : 10.1175/1520-0450(1979)018<0034:MLEOFC>2.0.CO;2
A Model Fitting Analysis of Daily Rainfall Data, Journal of the Royal Statistical Society. Series A (General), vol.147, issue.1, p.1, 1984. ,
DOI : 10.2307/2981736
A Bernstein polynomial approach to density function estimation. Statistical inference and related topics 2, pp.87-99, 1975. ,
DOI : 10.1016/b978-0-12-568002-8.50011-2
Stochastic downscaling of precipitation: From dry events to heavy rainfalls, Water Resources Research, vol.12, issue.213, pp.1-13, 2007. ,
DOI : 10.1175/1520-0442(1999)012<2474:TAMAAS>2.0.CO;2
Statistical downscaling of precipitation through nonhomogeneous stochastic weather typing, Climate Research, vol.34, issue.3, pp.169-184, 2007. ,
Conditioning stochastic daily precipitation models on total monthly precipitation, Water Resources Research, vol.18, issue.6, pp.1429-1439, 1989. ,
DOI : 10.1029/WR018i005p01461
Interannual variability and extreme-value characteristics of several stochastic daily precipitation models, Agricultural and Forest Meteorology, vol.93, issue.3, pp.153-169, 1999. ,
DOI : 10.1016/S0168-1923(98)00125-7
Statistical methods in the atmospheric sciences, 2011. ,
Maximum Likelihood Estimation of Fourier Coefficients to Describe Seasonal Variations of Parameters in Stochastic Daily Precipitation Models, Journal of Applied Meteorology, vol.18, issue.1, pp.34-42, 1979. ,
The occurrence and severity of droughts in South Africa, 1984. ,
