Enhancing Transparency and Consent in the IoT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The development of the IoT raises specific questions in terms of privacy, especially with respect to information to users and consent. We argue that (1) all necessary information about collected data and the collecting devices should be communicated electronically to all data subjects in their range and (2) data subjects should be able to reply also electronically and express their own privacy choices. In this position paper, we take some examples of technologies and initiatives to illustrate our position (including direct and registry-based communications) and discuss them in the light of the GDPR and the WP29 recommendations.
IWPE2018.pdf (133.43 Ko) Télécharger le fichier
hal-01709255 , version 1 (14-02-2018)
hal-01709255 , version 2 (15-02-2018)
Victor Morel, Daniel Le Métayer, Mathieu Cunche, Claude Castelluccia. Enhancing Transparency and Consent in the IoT. IWPE 2018 - International Workshop on Privacy Engineering, Apr 2018, London, United Kingdom. pp.116-119, ⟨10.1109/EuroSPW.2018.00023⟩. ⟨hal-01709255v2⟩
576 Consultations
1474 Téléchargements
