Odometric navigation with matching of landscape features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Navigation odométrique avec un recalage sur certaines balises de repérage géographique
This paper presents a technique to localize and guide outdoors vehicles by both vehicle odometry and landmark localization. In this case, we use reflective poles spaced out about 50 m apart and located at the front of the vehicle. The LADAR detects distances, angles, speed, and the position of obstacles within 20 m. Odometry is performed by a steering sensor and encoder attached at the vehicle differential. Using this information, the embedded system matches the vehicle's computed position with the location of the poles. Finally, passenger safety is ensured by an anti-collision subsystem thanks to the LADAR sensor.
01238517.pdf (483.86 Ko) Télécharger le fichier
ExplanationsabouttheKalmanfilteringanditsdiversessupportsofcalculation.pdf (20.6 Ko) Télécharger le fichier
On the error of the linear approximation done and also for the propagation of the uncertainties in the extended Kalman filter4.2.pdf (16.71 Ko) Télécharger le fichier
On the error of the linear approximation done and also for the propagation of the uncertainties in the extended Kalman filter4.3.pdf (17.86 Ko) Télécharger le fichier
On the error of the linear approximation done and also for the propagation of the uncertainties in the extended Kalman filter4.4.2.pdf (18.23 Ko) Télécharger le fichier
On the error of the linear approximation done and also for the propagation of the uncertainties in the extended Kalman filter4.pdf (15.5 Ko) Télécharger le fichier
Format : Figure, Image
Format : Présentation
Commentaire : Ici, je remets les recherches effectuées à l'institut dans le contexte d'une recherche plus globale entre 1960 et 2020
Format : Papier court
Commentaire : Ici je les charge un peu, pour les collègues qui sucent de l'énergie
Commentaire : Ici je devrais écrire 4.4 mais je préfère terminer en beauté avec la version numérotée 4.4.2, je ne sais pas trop comment l'indiquer et si c'est important de faire suivre les étapes importantes de cette construction donc je choisis 4.4.2 pour permettre une meilleure cohérence des archivages
Commentaire : Ici encore une petite faute de ma part sur le O(x) et pas le zéro
hal-01915083 , version 1 (07-11-2018)
Paternité
Michel Parent, Edern Ollivier. Odometric navigation with matching of landscape features. ICARCV 2002: The Seventh International Conference on Control, Automation, Robotics and Vision, IEEE, Dec 2002, Singapore, Singapore. pp.757-762, ⟨10.1109/ICARCV.2002.1238517⟩. ⟨hal-01915083⟩
Relations
1510 Consultations
342 Téléchargements
