Multi-scale modeling of urban air pollution: development and application of a Street-in-Grid model (v1.0) by coupling MUNICH (v1.0) and Polair3D (v1.8.1) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geoscientific Model Development Discussions Année : 2018
A new multi-scale model of urban air pollution is presented. This model combines a chemistry–transport model (CTM) that includes a comprehensive treatment of atmospheric chemistry and transport on spatial scales down to 1 km and a street-network model that describes the atmospheric concentrations of pollutants in an urban street network. The street-network model is the Model of Urban Network of Intersecting Canyons and Highways (MUNICH), which consists of two main components: a street-canyon component and a street-intersection component. MUNICH is coupled to the Polair3D CTM of the Polyphemus air quality modeling platform to constitute the Street-in-Grid (SinG) model. MUNICH is used to simulate the concentrations of the chemical species in the urban canopy, which is located in the lowest layer of Polair3D, and the simulation of pollutant concentrations above rooftops is performed with Po-lair3D. Interactions between MUNICH and Polair3D occur at roof level and depend on a vertical mass transfer coefficient that is a function of atmospheric turbulence. SinG is used to simulate the concentrations of nitrogen oxides (NO x) and ozone (O 3) in a Paris suburb. Simulated concentrations are compared to NO x concentrations measured at two monitoring stations within a street canyon. SinG shows better performance than MUNICH for nitrogen dioxide (NO 2) concentrations. However, both SinG and MUNICH underestimate NO x. For the case study considered, the model performance for NO x concentrations is not sensitive to using a complex chemistry model in MUNICH and the Leighton NO–NO 2 – O 3 set of reactions is sufficient.
gmd-11-611-2018.pdf (2.91 Mo) Télécharger le fichier
hal-01712812 , version 1 (19-02-2018)
Youngseob Kim, You Wu, Christian Seigneur, Yelva Roustan. Multi-scale modeling of urban air pollution: development and application of a Street-in-Grid model (v1.0) by coupling MUNICH (v1.0) and Polair3D (v1.8.1). Geoscientific Model Development Discussions, 2018, 11 (2), pp.611-629. ⟨10.5194/gmd-11-611-2018⟩. ⟨hal-01712812⟩
318 Consultations
192 Téléchargements
