Some insights into the migration of double imaginary roots under small deviation of two parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2018
This paper studies the migration of double imaginary roots of the systems' characteristic equation when two parameters are subjected to small deviations. The proposed approach covers a wide range of models. Under the least degeneracy assumptions, we found that the local stability crossing curve has a cusp at the point that corresponds to the double root, and it divides the neighborhood of this point into an S-sector and a G-sector. When the parameters move into the G-sector, one of the roots moves to the right half-plane, and the other moves to the left half-plane. When the parameters move into the S-sector, both roots move either to the left half-plane or the right half-plane depending on the sign of a quantity that depends on the characteristic function and its derivatives up to the third order.
autosam.pdf (735.35 Ko) Télécharger le fichier
hal-01712829 , version 1 (19-02-2018)
Dina Irofti, Keqin Gu, Islam Boussaada, Silviu-Iulian Niculescu. Some insights into the migration of double imaginary roots under small deviation of two parameters. Automatica, 2018, 88, pp.91-97. ⟨10.1016/j.automatica.2017.11.015⟩. ⟨hal-01712829⟩
207 Consultations
124 Téléchargements
