Evolutionary Optimization in Uncertain Environments???A Survey, IEEE Transactions on Evolutionary Computation, vol.9, issue.3, pp.303-317, 2005. ,
DOI : 10.1109/TEVC.2005.846356
Robust optimization ??? A comprehensive survey, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.33-34, pp.33-343190, 2007. ,
DOI : 10.1016/j.cma.2007.03.003
An Integrated Framework for Optimization Under Uncertainty Using Inverse Reliability Strategy, Journal of Mechanical Design, vol.125, issue.4, pp.562-570, 2004. ,
DOI : 10.1115/1.1759358
Multi-objective reliability-based optimization with stochastic metamodels, Evolutionary Computation, vol.19, issue.4, pp.525-560, 2011. ,
A new robust optimization approach for scheduling under uncertainty:, Computers & Chemical Engineering, vol.28, issue.6-7, pp.6-7, 2003. ,
DOI : 10.1016/j.compchemeng.2003.09.020
A new robust optimization approach for scheduling under uncertainty: ii. uncertainty with known probability distribution, Computers & Chemical Engineering, issue.3, pp.31171-195, 2007. ,
Trade-Off between Performance and Robustness: An Evolutionary Multiobjective Approach, pp.237-251, 2003. ,
DOI : 10.1007/3-540-36970-8_17
URL : http://www.soft-computing.de/jin-emo03.pdf
First-order second-moment approximation in reliability of structural systems: Critical review and alternative approach, Structural Safety, vol.1, issue.3, pp.211-231 ,
DOI : 10.1016/0167-4730(82)90027-3
A Procedure for Robust Design: Minimizing Variations Caused by Noise Factors and Control Factors, Journal of Mechanical Design, vol.22, issue.1, pp.478-485, 1996. ,
DOI : 10.1115/1.2826915
Robust design of structures using optimization methods, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.23-26, pp.23-262221, 2004. ,
DOI : 10.1016/j.cma.2003.12.055
A Preliminary Study on Handling Uncertainty in Indicator-Based Multiobjective Optimization, pp.727-739, 2006. ,
DOI : 10.1007/11732242_71
Handling Uncertainties in Evolutionary Multi-Objective Optimization Robustness analysis in multi-objective optimization using a degree of robustness concept, IEEE International Conference on Evolutionary Computation, pp.262-292, 2006. ,
A multi-objective genetic algorithm for robust design optimization, Proceedings of the 2005 conference on Genetic and evolutionary computation , GECCO '05, pp.771-778, 2005. ,
DOI : 10.1145/1068009.1068140
Introducing Robustness in Multi-Objective Optimization, Evolutionary Computation, vol.14, issue.4, pp.463-494, 2006. ,
DOI : 10.1109/4235.661550
Handling uncertainty in evolutionary multiobjective optimization: SPGA, 2007 IEEE Congress on Evolutionary Computation, pp.4130-4137, 2007. ,
DOI : 10.1109/CEC.2007.4425010
Evolutionary Multi-objective Ranking with Uncertainty and Noise, pp.329-343, 2001. ,
DOI : 10.1007/3-540-44719-9_23
Multi-objective optimisation in the presence of uncertainty, 2005 IEEE Congress on Evolutionary Computation, pp.243-250, 2005. ,
DOI : 10.1109/CEC.2005.1554691
Pareto-Front Exploration with Uncertain Objectives, pp.314-328, 2001. ,
DOI : 10.1007/3-540-44719-9_22
Competitive coevolutionary algorithm for robust multi-objective optimization: The worst case minimization, 2016 IEEE Congress on Evolutionary Computation (CEC), pp.586-593, 2016. ,
DOI : 10.1109/CEC.2016.7743846
Approximate implementations of pure random search in the presence of noise, Journal of Global Optimization, vol.31, issue.4, pp.601-612, 2005. ,
Simulated annealing for noisy cost functions, Journal of Global Optimization, vol.8, issue.1, pp.1-13, 1996. ,
On similarities between two models of global optimization: statistical models and radial basis functions, Journal of Global Optimization, vol.4, issue.1, pp.173-182, 2010. ,
DOI : 10.1007/3-540-50871-6_1
Evolutionary algorithms for multi-objective optimization problems with interval parameters, 2010 IEEE Fifth International Conference on Bio-Inspired Computing: Theories and Applications (BIC-TA), pp.411-420, 2010. ,
DOI : 10.1109/BICTA.2010.5645160
An Optimization Algorithm for Imprecise Multi-Objective Problem Functions, 2005 IEEE Congress on Evolutionary Computation, pp.459-466, 2005. ,
DOI : 10.1109/CEC.2005.1554719
URL : http://www.lania.mx/~ccoello/EMOO/limbourg05a.pdf.gz
Interval Robust Multi-Objective Evolutionary Algorithm, 2009 IEEE Congress on Evolutionary Computation, pp.1637-1643, 2009. ,
DOI : 10.1109/CEC.2009.4983138
Unified Uncertainty Analysis by the First Order Reliability Method, Journal of Mechanical Design, vol.100, issue.9, pp.91401-091401, 2008. ,
DOI : 10.1016/0045-7949(78)90046-9
Multi-objective Optimization of Problems with Epistemic Uncertainty, pp.413-427, 2005. ,
DOI : 10.1007/978-3-540-31880-4_29
Recent advances in robust optimization: An overview, European Journal of Operational Research, vol.235, issue.3, pp.471-483, 2014. ,
DOI : 10.1016/j.ejor.2013.09.036
URL : https://hal.archives-ouvertes.fr/hal-01495346
Robustness for uncertain multi-objective optimization: a survey and analysis of different concepts, OR Spectrum, vol.159, issue.1, pp.235-271, 2016. ,
DOI : 10.1007/s10957-012-0234-z
Lexicographic ??-robustness: An alternative to min???max criteria, European Journal of Operational Research, vol.220, issue.3, pp.722-728, 2012. ,
DOI : 10.1016/j.ejor.2012.01.056
Bi-objective robust optimisation, European Journal of Operational Research, vol.252, issue.2, pp.418-431, 2016. ,
DOI : 10.1016/j.ejor.2016.01.015
Robustness in operational research and decision aiding: A multi-faceted issue, European Journal of Operational Research, vol.200, issue.3, pp.629-638, 2010. ,
DOI : 10.1016/j.ejor.2008.12.036
Comparing Solutions under Uncertainty in Multiobjective Optimization, Mathematical Problems in Engineering, vol.6239, pp.1-10, 2014. ,
DOI : 10.1016/S0045-7825(99)00394-1
An adaptive strategy on the error of the objective functions for uncertainty-based derivative-free optimization, Journal of Computational Physics, vol.309, pp.241-266, 2016. ,
DOI : 10.1016/j.jcp.2016.01.004
URL : https://hal.archives-ouvertes.fr/hal-01378411
Using approximations to accelerate engineering design optimizationISSMO Symposium on Multidisciplinary Analysis and Optimization: A Collection of Technical Papers, 7th, pp.738-748, 1998. ,
A framework for evolutionary optimization with approximate fitness functions, IEEE Transactions on Evolutionary Computation, vol.6, issue.5, pp.481-494, 2002. ,
Surrogate-assisted evolutionary computation: Recent advances and future challenges, Swarm and Evolutionary Computation, vol.1, issue.2, pp.61-70, 2011. ,
DOI : 10.1016/j.swevo.2011.05.001
Metamodel???Assisted Evolution Strategies, pp.361-370, 2002. ,
DOI : 10.1007/3-540-45712-7_35
URL : http://www.liacs.nl/~emmerich/pdf/EGO+02.pdf
Single- and multiobjective evolutionary optimization assisted by Gaussian random field metamodels, IEEE Transactions on Evolutionary Computation, vol.10, issue.4, pp.421-439, 2006. ,
DOI : 10.1109/TEVC.2005.859463
URL : http://www.liacs.nl/~emmerich/pdf/ENG06.pdf
Accelerating Evolutionary Algorithms With Gaussian Process Fitness Function Models, IEEE Transactions on Systems, Man and Cybernetics, Part C (Applications and Reviews), vol.35, issue.2, pp.183-194, 2005. ,
DOI : 10.1109/TSMCC.2004.841917
URL : http://wanda.fh-aargau.ch/staff/bueche/publications/Bueche2004a.pdf
