Direct Calophyllum oil extraction and resin separation with a binary solvent of n-hexane and methanol mixture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fuel Année : 2018
Ika Amalia Kartika
  • Fonction : Auteur
  • PersonId : 940441
Muriel Cerny
  • Fonction : Auteur
  • PersonId : 1019066
Virginie Vandenbossche
  • Fonction : Auteur
  • PersonId : 1202986
Caroline Sablayrolles
Claire Vialle
Philippe Evon
This study investigated the use of a mixture of n-hexane and methanol as a binary solvent for the direct oil extraction and resin separation from Calophyllum seeds, in a single step. Optimal oil and resin yields and physicochemical properties were determined by identifying the best extraction conditions. The solvent mixture tested extracted oil and resin effectively from Calophyllum seeds, and separated resin from oil. Extraction conditions affected oil and resin yields and their physicochemical properties, with the n-hexane-to-methanol ratio being the most critical factor. Oil yield improved as n-hexane-to-methanol ratio increased from 0.5:1 to 2:1, and resin yield increased as methanol-to-n-hexane ratio increased from 0.5:1 to 2:1. Physicochemical properties of oil and resin, particularly for acid value and impurity content, improved as the n-hexane-to-methanol ratio decreased from 2:1 to 0.5:1. The best oil (51% with more than 95% triglycerides) and resin (18% with more than 5% polyphenols) yields were obtained with n-hexane-to-methanol ratios of 2:1 and 0.5:1, respectively, at a temperature of 50 °C, with an extraction time of 5 h. The best values for physicochemical property of oil were a density of 0.885 g/cm3, a viscosity of 26.0 mPa.s, an acid value of 13 mg KOH/g, an iodine value of 127 g/100 g, an unsaponifiable content of 1.5%, a moisture content of 0.8% and an ash content of 0.04%.
Kartika_19585.pdf (274.36 Ko) Télécharger le fichier
hal-01713906 , version 1 (21-02-2018)
Ika Amalia Kartika, Muriel Cerny, Virginie Vandenbossche, Luc Rigal, Caroline Sablayrolles, et al.. Direct Calophyllum oil extraction and resin separation with a binary solvent of n-hexane and methanol mixture. Fuel, 2018, 221, pp.159-164. ⟨10.1016/j.fuel.2018.02.080⟩. ⟨hal-01713906⟩
112 Consultations
514 Téléchargements
