The non-linear sewing lemma I: weak formulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We introduce a new framework to deal with rough differential equations based on flows and their approximations. Our main result is to prove that measurable flows exist under weak conditions, even solutions to the corresponding rough differential equations are not unique. We show that under additional conditions of the approximation, there exists a unique Lipschitz flow. Then, a perturbation formula is given. Finally, we link our approach to the additive, multiplicative sewing lemmas and the rough Euler scheme.
non-linear-sewing-lemma-I-v2.pdf (386.57 Ko) Télécharger le fichier
hal-01716945 , version 1 (25-02-2018)
hal-01716945 , version 2 (26-10-2018)
hal-01716945 , version 3 (25-02-2019)
hal-01716945 , version 4 (25-02-2019)
hal-01716945 , version 5 (15-05-2019)
Antoine Brault, Antoine Lejay. The non-linear sewing lemma I: weak formulation. 2018. ⟨hal-01716945v2⟩
982 Consultations
472 Téléchargements
