Conference papers
Instance Optimal Decoding and the Restricted Isometry Property
Abstract : In this paper, we address the question of information preservation in ill-posed, non-linear inverse problems, assuming that the measured data is close to a low-dimensional model set. We provide necessary and sufficient conditions for the existence of a so-called instance optimal decoder, i.e., that is robust to noise and modelling error. Inspired by existing results in compressive sensing, our analysis is based on a (Lower) Restricted Isometry Property (LRIP), formulated in a non-linear fashion. We also provide sufficient conditions for non-uniform recovery with random measurement operators, with a new formulation of the LRIP. We finish by describing typical strategies to prove the LRIP in both linear and non-linear cases, and illustrate our results by studying the invertibility of a one-layer neural net with random weights.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01718411
Contributor : Nicolas Keriven Connect in order to contact the contributor
Submitted on : Thursday, March 1, 2018 - 11:30:17 AM
Last modification on : Friday, January 21, 2022 - 3:09:31 AM
Long-term archiving on: : Wednesday, May 30, 2018 - 12:57:32 PM
main.pdf
Identifiers
Citation
Nicolas Keriven, Rémi Gribonval. Instance Optimal Decoding and the Restricted Isometry Property. 8th International Conference on New Computational Methods for Inverse Problems (NCMIP), May 2018, Cachan, France. pp.012002, ⟨10.1088/1742-6596/1131/1/012002⟩. ⟨hal-01718411v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
