Formalization Techniques for Asymptotic Reasoning in Classical Analysis - Archive ouverte HAL Access content directly
Journal Articles Journal of Formalized Reasoning Year : 2018
(1) , (2) , (2)
1
2
Formalizing analysis on a computer involves a lot of “epsilon-delta” reasoning, while informal reasoning may use some asymptotical hand-waving. Whether or not the arithmetic details are hidden using some abstraction like filters, a human user eventually has to break it down for the proof assistant anyway, and provide a witness for the existential variable “delta”. We describe formalization techniques that take advantage of existential variables to delay the input of witnesses until a stage where the proof assistant can actually infer them. We use these techniques to prove theorems about classical analysis and to provide equational Bachmann-Landau notations. This partially restores the simplicity of informal hand-waving without compromising the proof. As expected this also reduces the size of proof scripts and the time to write them, and it also makes proofs more stable.
8124-27375-1-PB.pdf (434.74 Ko) Télécharger le fichier
Dates and versions
hal-01719918 , version 1 (28-02-2018)
hal-01719918 , version 2 (12-06-2018)
hal-01719918 , version 3 (30-10-2018)
Identifiers
  • HAL Id : hal-01719918 , version 3
Cite
Reynald Affeldt, Cyril Cohen, Damien Rouhling. Formalization Techniques for Asymptotic Reasoning in Classical Analysis. Journal of Formalized Reasoning, 2018. ⟨hal-01719918v3⟩
509 View
376 Download
Share
