Impedance Transmission Conditions for the Electric Potential across a Highly Conductive Casing, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01412369
Asymptotic Analysis of Shell-like Inclusions with??High??Rigidity, Journal of Elasticity, vol.47, issue.123, pp.153-172, 2011. ,
DOI : 10.1016/0022-247X(74)90023-7
URL : https://hal.archives-ouvertes.fr/hal-00790346
Effective transmission conditions for thin-layer transmission problems in elastodynamics. The case of a planar layer model, ESAIM: Mathematical Modelling and Numerical Analysis, vol.50, issue.1, pp.43-75, 2016. ,
DOI : 10.1049/PBEW041E
URL : https://hal.archives-ouvertes.fr/hal-00937962
Compensation effect analysis in DIE method for through-casing measuring formation resistivity, Journal of Applied Geophysics, vol.74, issue.4, pp.287-293, 2011. ,
New post-processing method for interpretation of through casing resistivity (TCR) measurements, Journal of Applied Geophysics, vol.74, issue.1, pp.19-25, 2011. ,
DOI : 10.1016/j.jappgeo.2011.02.011
High-order accurate thin layer approximations for time-domain electromagnetics, Part II: Transmission layers, Journal of Computational and Applied Mathematics, vol.234, issue.8, pp.2587-2608, 2010. ,
DOI : 10.1016/j.cam.2010.03.022
URL : https://hal.archives-ouvertes.fr/hal-00739326
High-order accurate thin layer approximations for time-domain electromagnetics. Part I: General metal backed coatings, Journal of Computational and Applied Mathematics, vol.231, issue.2, pp.598-611, 2009. ,
DOI : 10.1016/j.cam.2009.04.019
Modèles et asymptotiques des interfaces fines et périodiques enélectromagnétismeen´enélectromagnétisme, 2010. ,
Approximate models for wave propagation across thin periodic interfaces, Journal de Math??matiques Pures et Appliqu??es, vol.98, issue.1, pp.28-71, 2012. ,
DOI : 10.1016/j.matpur.2012.01.003
URL : https://hal.archives-ouvertes.fr/hal-00741614
Equivalent Robin boundary conditions for acoustic and elastic media, Mathematical Models and Methods in Applied Sciences, vol.414, issue.08, pp.1531-1566, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01254194
TIME-HARMONIC MAXWELL EQUATIONS IN BIOLOGICAL CELLS ??? THE DIFFERENTIAL FORM FORMALISM TO TREAT THE THIN LAYER, Confluentes Mathematici, vol.10, issue.02, pp.325-357, 2011. ,
DOI : 10.1163/156939396X00504
Abstract, Communications in Computational Physics, vol.144, issue.01, pp.213-238, 2014. ,
DOI : 10.1088/0031-9155/46/1/315
Fast inversion of 3D Borehole Resistivity Measurements using Model Reduction Techniques based on 1D Semi-Analytical Solutions, 2016. ,
The electrical field in a borehole with a casing, GEOPHYSICS, vol.55, issue.1, pp.29-38, 1990. ,
DOI : 10.1190/1.1442769
A transmission???line model for electrical logging through casing, GEOPHYSICS, vol.58, issue.12, pp.1739-1747, 1993. ,
DOI : 10.1190/1.1443388
PML Enhanced with a Self-Adaptive Goal-Oriented $hp$-Finite Element Method: Simulation of Through-Casing Borehole Resistivity Measurements, SIAM Journal on Scientific Computing, vol.30, issue.6, pp.2948-2964, 2008. ,
DOI : 10.1137/070689796
A goal-orientedhp-adaptive finite element method with electromagnetic applications. Part I: electrostatics, International Journal for Numerical Methods in Engineering, vol.20, issue.8, pp.1269-1309, 2006. ,
DOI : 10.1002/nme.1488
Simulation of multifrequency borehole resistivity measurements through metal casing using a goal-oriented hp finite-element method. Geoscience and Remote Sensing, IEEE Transactions on, issue.8, pp.442125-2134, 2006. ,
Feasibility study for 2D frequency-dependent electromagnetic sensing through casing, GEOPHYSICS, vol.72, issue.3, pp.111-118, 2007. ,
DOI : 10.1190/1.1443600
Simulations of 3D DC borehole resistivity measurements with a goal-oriented hp finite-element method. Part II: through-casing resistivity instruments, Computational Geosciences, vol.59, issue.3, pp.83-89, 2008. ,
DOI : 10.1007/s10596-007-9061-y
Sensitivity study of borehole-to-surface and crosswell electromagnetic measurements acquired with energized steel casing to water displacement in hydrocarbon-bearing layers, GEOPHYSICS, vol.73, issue.6, pp.73-261, 2008. ,
DOI : 10.1190/1.1443821
Mathematical modeling of electromagnetic phenomena in high contrast media. Theses, 2009. ,
Equivalent Boundary Conditions for an Elasto-Acoustic Problem set in a Domain with a Thin Layer, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, issue.5, pp.1431-1449, 2014. ,
DOI : 10.1051/m2an:2000106
Asymptotic Models for Acoustic, Elastic and Electromagnetic Media. Corner and Edge Asymptotics for Elliptic Systems. Habilitationà Habilitation`Habilitationà diriger des recherches, 2017. ,
Equivalent Transmission Conditions for the Time-Harmonic Maxwell Equations in 3D for a Medium with a Highly Conductive Thin Sheet, SIAM Journal on Applied Mathematics, vol.76, issue.3, pp.1031-1052, 2016. ,
DOI : 10.1137/15M1012116
Asymptotic expansion of steady-state potential in a high contrast medium with a thin resistive layer, Applied Mathematics and Computation, vol.221, pp.48-65, 2013. ,
DOI : 10.1016/j.amc.2013.06.047
URL : https://hal.archives-ouvertes.fr/inria-00442659
A Unified Analysis of Transmission Conditions for Thin Conducting Sheets in the Time-Harmonic Eddy Current Model, SIAM Journal on Applied Mathematics, vol.73, issue.6, pp.1980-2003, 2013. ,
DOI : 10.1137/120901398
High order transmission conditions for thin conductive sheets in magneto-quasistatics, ESAIM: Mathematical Modelling and Numerical Analysis, vol.44, issue.6, pp.1115-1140, 2011. ,
DOI : 10.1109/TMAG.2008.915834
URL : https://hal.archives-ouvertes.fr/inria-00473213
