Impedance Transmission Conditions for the Electric Potential across a Highly Conductive Casing, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01403347
Asymptotic analysis of shell-like inclusions with high rigidity, Journal of Elasticity, vol.103, issue.2, pp.153-172, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00790346
Effective transmission conditions for thin-layer transmission problems in elastodynamics. The case of a planar layer model, ESAIM: Mathematical Modelling and Numerical Analysis, vol.50, pp.43-75, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00937962
Compensation effect analysis in DIE method for through-casing measuring formation resistivity, Journal of Applied Geophysics, vol.74, issue.4, pp.287-293, 2011. ,
New post-processing method for interpretation of through casing resistivity (TCR) measurements, Journal of Applied Geophysics, vol.74, issue.1, pp.19-25, 2011. ,
High-order accurate thin layer approximations for time-domain electromagnetics. Part II: transmission layers, Journal of Computational and Applied Mathematics, vol.234, issue.8, pp.2587-2608, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00739326
High-order accurate thin layer approximations for time-domain electromagnetics. Part I: General metal backed coatings, Journal of computational and applied mathematics, vol.231, issue.2, pp.598-611, 2009. ,
Neumann and mixed problems on curvilinear polyhedra, Integral Equations Operator Theory, vol.15, pp.227-261, 1992. ,
Modèles et asymptotiques des interfaces fines et périodiques enélectromagnétismeen´enélectromagnétisme, 2010. ,
Approximate models for wave propagation across thin periodic interfaces, Journal de mathématiques pures et appliquées, vol.98, issue.1, pp.28-71, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00741614
Equivalent Robin boundary conditions for acoustic and elastic media, Math. Models Methods Appl. Sci, vol.26, issue.8, pp.1531-1566, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01254193
Time-harmonic maxwell equations in biological cells. the differential form formalism to treat the thin layer, Confluentes Mathematici, vol.3, issue.02, pp.325-357, 2011. ,
Thin layer models for electromagnetism, Communications in Computational Physics, vol.16, pp.213-238, 2014. ,
Fast inversion of 3D Borehole Resistivity Measurements using Model Reduction Techniques based on 1D Semi-Analytical Solutions, 2016. ,
The electrical field in a borehole with a casing, Geophysics, vol.55, issue.1, pp.29-38, 1990. ,
A transmission-line model for electrical logging through casing, Geophysics, vol.58, issue.12, pp.1739-1747, 1993. ,
DOI : 10.1190/1.1443388
PML enhanced with a self-adaptive goal-oriented hp-finite element method: Simulation of through-casing borehole resistivity measurements, SIAM Journal on Scientific Computing, vol.30, issue.6, pp.2948-2964, 2008. ,
DOI : 10.1137/070689796
URL : http://uts.cc.utexas.edu/~cefe/CFE PDFs/22-FERefJourPubs.pdf
A goal-oriented hp-adaptive finite element method with electromagnetic applications. Part I: electrostatics, International Journal for Numerical Methods in Engineering, vol.65, issue.8, pp.1269-1309, 2006. ,
DOI : 10.1016/j.cma.2006.10.016
Simulation of multifrequency borehole resistivity measurements through metal casing using a goal-oriented hp finite-element method. Geoscience and Remote Sensing, IEEE Transactions on, vol.44, issue.8, pp.2125-2134, 2006. ,
DOI : 10.1109/tgrs.2006.872094
Feasibility study for 2D frequency-dependent electromagnetic sensing through casing, Geophysics, vol.72, issue.3, pp.111-118, 2007. ,
DOI : 10.1190/1.2712058
Simulations of 3D DC borehole resistivity measurements with a goal-oriented hp finite-element method. Part II: through-casing resistivity instruments, Computational Geosciences, vol.12, issue.1, pp.83-89, 2008. ,
Sensitivity study of borehole-to-surface and crosswell electromagnetic measurements acquired with energized steel casing to water displacement in hydrocarbon-bearing layers, Geophysics, vol.73, issue.6, pp.261-268, 2008. ,
Mathematical modeling of electromagnetic phenomena in high contrast media. Theses, Université Rennes 1, 2009. ,
Equivalent boundary conditions for an elasto-acoustic problem set in a domain with a thin layer, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, issue.5, pp.1431-1449, 2014. ,
Asymptotic Models for Acoustic, Elastic and Electromagnetic Media. Corner and Edge Asymptotics for Elliptic Systems. Habilitationà Habilitation`Habilitationà diriger des recherches, 2017. ,
Equivalent transmission conditions for the time-harmonic Maxwell equations in 3D for a medium with a highly conductive thin sheet, SIAM Journal on Applied Mathematics, vol.76, issue.3, pp.1031-1052, 2016. ,
Asymptotic expansion of steady-state potential in a high contrast medium with a thin resistive layer, Applied Mathematics and Computation, vol.221, pp.48-65, 2013. ,
URL : https://hal.archives-ouvertes.fr/inria-00442659
A unified analysis of transmission conditions for thin conducting sheets in the time-harmonic eddy current model, SIAM Journal on Applied Mathematics, vol.73, issue.6, pp.1980-2003, 2013. ,
High order transmission conditions for thin conductive sheets in magneto-quasistatics, ESAIM: Mathematical Modelling and Numerical Analysis, vol.45, issue.06, pp.1115-1140, 2011. ,
DOI : 10.1051/m2an/2011009
URL : https://hal.archives-ouvertes.fr/inria-00473213
