Vision-based Force Feedback Estimation for Robot-assisted Surgery using Instrument-constrained Biomechanical 3D Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2018
We present a method for estimating visual and haptic force feedback on robotic surgical systems that currently do not include significant force feedback for the operator. Our approach permits to compute contact forces between instruments and tissues without additional sensors, relying only on endoscopic images acquired by a stereoscopic camera. Using an underlying biomechanical model built on-the-fly from the organ shape and by considering the surgical tool as boundary conditions acting on the surface of the model, contact force can be estimated at the tip of the tool. At the same time these constraints generate stresses that permit to compose a new endoscopic image as visual feedback for the surgeon. The results are demonstrated on in- vivo sequences of a human liver during robotic surgery, while quantitative validation is performed on an DejaVu and ex-vivo experimentation with ground truth to show the advantage of our approach.
17-0884_06_MS.pdf (3.21 Mo) Télécharger le fichier
Screen Shot 2018-03-01 at 1.07.58 AM.png (165.42 Ko) Télécharger le fichier
Format : Figure, Image
hal-01720259 , version 1 (01-03-2018)
Nazim Haouchine, Winnie Kuang, Stéphane Cotin, Michael Yip. Vision-based Force Feedback Estimation for Robot-assisted Surgery using Instrument-constrained Biomechanical 3D Maps. IEEE Robotics and Automation Letters, 2018, ⟨10.1109/LRA.2018.2810948⟩. ⟨hal-01720259⟩
630 Consultations
930 Téléchargements
