Zinc oxide nano-enabled microfluidic reactor for water purification and its applicability to volatile organic compounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microsystems & Nanoengineering Année : 2018
This paper reports fast and efficient chemical decontamination of water within a tree-branched centimeter-scale microfluidic reactor. The microreactor integrates Zinc oxide nanowires (ZnO NWs) in situ grown acting as an efficient photocatalytic nanomaterial layer. Direct growth of ZnO NWs within the microfluidic chamber brings this photocatalytic medium at the very close vicinity of the water flow path, hence minimizing the required interaction time to produce efficient purification performance. We demonstrate a degradation efficiency of 95% in o 5 s of residence time in one-pass only. According to our estimates, it becomes attainable using microfluidic reactors to produce decontamination of merely 1 l of water per day, typical of the human daily drinking water needs. To conduct our experiments, we have chosen a laboratory-scale case study as a seed for addressing the health concern of water contamination by volatile organic compounds (VOCs), which remain difficult to remove using alternative decontamination techniques, especially those involving water evaporation. The contaminated water sample contains mixture of five pollutants: Benzene; Toluene; Ethylbenzene; m-p Xylenes; and o-Xylene (BTEX) diluted in water at 10 p.p.m. concentration of each. Degradation was analytically monitored in a selective manner until it falls below 1 p.p.m. for each of the five pollutants, corresponding to the maximum contaminant level (MCL) established by the US Environmental Protection Agency (EPA). We also report on a preliminary study, investigating the nature of the chemical by-products after the photocatalytic VOCs degradation process.
micronano201793.pdf (1.69 Mo) Télécharger le fichier
hal-01721133 , version 1 (12-06-2019)
Paternité
Imadeddine Azzouz, Yamina Ghozlane Habba, Martine Capochichi-Gnambodoe, Frédéric Marty, Jerome Vial, et al.. Zinc oxide nano-enabled microfluidic reactor for water purification and its applicability to volatile organic compounds. Microsystems & Nanoengineering, 2018, 4, pp.17093. ⟨10.1038/micronano.2017.93⟩. ⟨hal-01721133⟩
272 Consultations
140 Téléchargements
