Z. Zhou, Y. Li, J. Liu, and G. Li, Equality constrained robust measurement fusion for adaptive kalman-filter-based heterogeneous multi-sensor navigation, IEEE Trans. Aerosp. Electron. Syst, vol.49, pp.2146-2157, 2013.
Z. Zhou, Y. Li, J. Zhang, and C. Rizos, Integrated Navigation System for a Low-Cost Quadrotor Aerial Vehicle in the Presence of Rotor Influences, J. Surv. Eng, p.5016006, 2017.
G. Chang, T. Xu, and Q. Wang, M-estimator for the 3D symmetric Helmert coordinate transformation, J. Geod, vol.92, pp.47-58, 2017.
Y. Wu, J. Wang, and D. Hu, A New Technique for INS/GNSS Attitude and Parameter Estimation Using Online Optimization, IEEE Trans. Signal Process, vol.62, pp.2642-2655, 2014.
L. Chang, F. Qin, and F. Zha, Pseudo Open-Loop Unscented Quaternion Estimator for Attitude Estimation, IEEE Sens. J, vol.16, pp.4460-4469, 2016.
S. Han and J. Wang, Quantization and colored noises error modeling for inertial sensors for GPS/INS integration, IEEE Sens. J, vol.11, pp.1493-1503, 2011.
L. Chang, J. Li, and S. Chen, Initial Alignment by Attitude Estimation for Strapdown Inertial Navigation Systems, IEEE Trans. Instrum. Meas, vol.64, pp.784-794, 2015.
J. Marins, X. Yun, E. Bachmann, R. Mcghee, and M. Zyda, An extended Kalman filter for quaternion-based orientation estimation using MARG sensors, Proceedings of the 2001 IEEE/RSJ International Conference on Intelligent Robots and Systems. Expanding the Societal Role of Robotics in the the Next Millennium (Cat. No.01CH37180), vol.4, 2001.
Y. Tian, H. Wei, and J. Tan, An adaptive-gain complementary filter for real-time human motion tracking with MARG sensors in free-living environments, IEEE Trans. Neural Syst. Rehabil. Eng, vol.21, pp.254-264, 2013.
J. Wu, Z. Zhou, R. Li, L. Yang, and H. Fourati, Attitude Determination Using a Single Sensor Observation : Analytic Quaternion Solutions and Property Discussion, IET Sci. Meas. Technol, vol.11, pp.731-739, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01514132
, Remote Sens, vol.10, pp.377-404, 2018.
S. Du and Y. Gao, Inertial aided cycle slip detection and identification for integrated PPP GPS and INS, Sensors, vol.12, pp.14344-14362, 2012.
A. Aleshechkin, Algorithm of GNSS-based attitude determination, 2011.
M. Grewal, A. K. Andrews, and . Filtering, Theory and Practice Using MATLAB
X. Niu, S. Nassar, and N. El-sheimy, An Accurate Land-Vehicle MEMS IMU/GPS Navigation System Using 3D Auxiliary Velocity Updates, vol.54, pp.177-188, 2007.
X. Niu, S. Nasser, C. Goodall, and N. El-sheimy, A universal approach for processing any MEMS inertial sensor configuration for land-vehicle navigation, J. Navig, vol.60, pp.233-245, 2007.
D. Gebre-egziabher and G. H. Elkaim, MAV attitude determination by vector matching, IEEE Trans. Aerosp. Electron. Syst, p.44, 2008.
J. Zhang, K. Zhang, R. Grenfell, and R. Deakin, Short note: On the relativistic Doppler effect for precise velocity determination using GPS, J. Geod, vol.80, pp.104-110, 2006.
Z. Zhou and B. Li, Optimal Doppler-aided smoothing strategy for GNSS navigation. GPS Solut, vol.21, pp.197-210, 2017.
J. Geng, Y. Bock, D. Melgar, B. W. Crowell, and J. S. Haase, A new seismogeodetic approach applied to GPS and accelerometer observations of the 2012 Brawley seismic swarm: Implications for earthquake early warning, Geochem. Geophys. Geosyst, vol.14, pp.2124-2142, 2013.
J. Geng, D. Melgar, Y. Bock, E. Pantoli, and J. Restrepo, Recovering coseismic point ground tilts from collocated high-rate GPS and accelerometers, Geophys. Res. Lett, vol.40, pp.5095-5100, 2013.
G. Wahba, A Least Squares Estimate of Satellite Attitude, SIAM Rev, vol.7, p.409, 1965.
M. D. Shuster and S. D. Oh, Three-axis attitude determination from vector observations, J. Guid. Control Dyn, vol.4, pp.70-77, 1981.
F. L. Markley, Attitude Determination using Vector Observations and the Singular Value Decomposition, J. Astronaut. Sci, vol.36, pp.245-258, 1988.
D. Mortari, ESOQ: A Closed-Form Solution to the Wahba Problem, J. Astronaut. Sci, vol.45, pp.195-204, 1997.
P. B. Davenport, A Vector Approach to the Algebra of Rotations with Applications, National Aeronautics and Space Administration, 1968.
G. Chang, T. Xu, and Q. Wang, Error analysis of Davenport's q method, Automatica, vol.75, pp.217-220, 2017.
J. Wu, Z. Zhou, B. Gao, R. Li, Y. Cheng et al., Fast Linear Quaternion Attitude Estimator Using Vector Observations, IEEE Trans. Autom. Sci. Eng, vol.15, pp.307-319, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01513263
Y. Yang and Z. Zhou, An analytic solution to Wahbas problem, Aerosp. Sci. Technol, vol.30, p.24, 2013.
Y. Yang, Attitude determination using Newton's method on Riemannian manifold, Proc. Inst. Mech. Eng. Part G J. Aerosp. Eng, vol.229, pp.2737-2742, 2015.
J. R. Forbes and A. H. De-ruiter, Linear-Matrix-Inequality-Based Solution to Wahba's Problem, J. Guid. Control Dyn, vol.38, pp.147-151, 2015.
R. Mahony, T. Hamel, and J. M. Pflimlin, Nonlinear complementary filters on the special orthogonal group, IEEE Trans. Autom. Control, vol.53, pp.1203-1218, 2008.
URL : https://hal.archives-ouvertes.fr/hal-00488376
S. O. Madgwick, A. J. Harrison, and R. Vaidyanathan, Estimation of IMU and MARG orientation using a gradient descent algorithm, Proceedings of the IEEE International Conference on Rehabilitation Robotics, 2011.
K. S. Arun, T. S. Huang, and S. D. Blostein, Least-Squares Fitting of Two 3-D Point Sets, IEEE Trans. Pattern Anal. Mach. Intell, pp.698-700, 1987.
C. Ye, S. Hong, and A. Tamjidi, 6-DOF Pose Estimation of a Robotic Navigation Aid by Tracking Visual and Geometric Features, IEEE Trans. Autom. Sci. Eng, vol.12, pp.1169-1180, 2015.
M. Abdelrahman and S. Y. Park, Simultaneous spacecraft attitude and orbit estimation using magnetic field vector measurements, Aerosp. Sci. Technol, vol.15, pp.653-669, 2011.
F. L. Markley and D. Mortari, Quaternion attitude estimation using vector observations, J. Astronaut. Sci, vol.48, pp.359-380, 2000.
F. L. Markley and D. Mortari, How to estimate attitude from vector observations, Adv. Astronaut. Sci, vol.103, pp.1979-1996, 2000.
F. L. Markley, Humble problems, Adv. Astronaut. Sci, vol.124, pp.2205-2222, 2006.
, Remote Sens, vol.10, pp.377-405, 2018.
J. Wu, Z. Zhou, J. Chen, H. Fourati, and R. Li, Fast Complementary Filter for Attitude Estimation Using Low-Cost MARG Sensors, IEEE Sens. J, vol.16, pp.6997-7007, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01368473
M. D. Shuster, Filter QUEST or REQUEST, J. Guid. Control Dyn, vol.32, pp.643-645, 2009.
R. G. Valenti, I. Dryanovski, and J. Xiao, A Linear Kalman Filter for MARG Orientation Estimation Using the Algebraic Quaternion Algorithm, IEEE Trans. Instrum. Meas, vol.65, pp.467-481, 2016.
R. A. Horn and C. R. Johnson, Matrix Analysis, 2012.
Y. Yang, Spacecraft attitude determination and control: Quaternion based method, Annu. Rev. Control, vol.36, pp.198-219, 2012.
Y. Cheng and M. D. Shuster, Improvement to the Implementation of the QUEST Algorithm, J. Guid. Control Dyn, vol.37, pp.301-305, 2014.
Y. Wu and W. Shi, This article is an open access article distributed under the terms and conditions of the Creative Commons Attribution, IEEE Sens. J, vol.15, pp.6424-6431, 2015.
