Resource Polymorphism - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
(1)
1
We present a resource-management model for ML-style programming languages, designed to be compatible with the OCaml philosophy and runtime model. This is a proposal to extend the OCaml language with destructors, move semantics, and resource polymorphism, to improve its safety, efficiency, interoperability, and expressiveness. It builds on the ownership-and-borrowing models of systems programming languages (Cyclone, C++11, Rust) and on linear types in functional programming (Linear Lisp, Clean, Alms). It continues a synthesis of resources from systems programming and resources in linear logic initiated by Baker. It is a combination of many known and some new ideas. On the novel side, it highlights the good mathematical structure of Stroustrup's “Resource acquisition is initialisation” (RAII) idiom for resource management based on destructors, a notion sometimes confused with finalizers, and builds on it a notion of resource polymorphism, inspired by polarisation in proof theory, that mixes C++'s RAII and a tracing garbage collector (GC). In particular, it proposes to identify the types of GCed values with types with trivial destructor: from this definition it deduces a model in which GC is the default allocation mode, and where GCed values can be used without restriction both in owning and borrowing contexts. The proposal targets a new spot in the design space, with an automatic and predictable resource-management model, at the same time based on lightweight and expressive language abstractions. It is backwards-compatible: current code is expected to run with the same performance, the new abstractions fully combine with the current ones, and it supports a resource-polymorphic extension of libraries. It does so with only a few additions to the runtime, and it integrates with the current GC implementation. It is also compatible with the upcoming multicore extension, and suggests that the Rust model for eliminating data-races applies. Interesting questions arise for a safe and practical type system, many of which have already been thoroughly investigated in the languages and prototypes Cyclone, Rust, and Alms.
ocaml-raii.pdf (425.02 Ko) Télécharger le fichier
Dates and versions
hal-01724997 , version 1 (07-03-2018)
Identifiers
  • HAL Id : hal-01724997 , version 1
Cite
Guillaume Munch-Maccagnoni. Resource Polymorphism. 2018. ⟨hal-01724997⟩
1841 View
3939 Download
Share
