Computational interpretations of linear logic, Theoretical Computer Science, vol.111, issue.1-2, pp.1-2, 1993. ,
DOI : 10.1016/0304-3975(93)90181-R
Engineering the servo web browser engine using Rust, Proceedings of the 38th International Conference on Software Engineering Companion, ICSE '16, 2016. ,
DOI : 10.1145/2184489.2184508
Liveness-Based Garbage Collection Held as Part of the European Joint Conferences on Theory and Practice of Software, Compiler Construction -23rd International Conference Proceedings (Lecture Notes in Computer Science), pp.85-106, 2014. ,
A unified theory of garbage collection, Proceedings of the 19th Annual ACM SIGPLAN Conference on Object-Oriented Programming, Systems, Languages, and Applications, pp.50-68, 2004. ,
Linear logic and permutation stacks -the Forth shall be first. SIG- ARCH Computer Architecture News, pp.34-43, 1994. ,
Minimum Reference Count Updating with Deferred and Anchored Pointers for Functional Data Structures, SIGPLAN Notices, vol.29, issue.52, pp.38-43, 1994. ,
Use-Once" Variables and Linear Objects -Storage Management, Reflection and Multi-Threading, SIGPLAN Notices, vol.30, issue.53, pp.45-52, 1995. ,
The Design and Formalization of Mezzo, a Permission-Based Programming Language, ACM Transactions on Programming Languages and Systems, vol.38, issue.4, p.54, 2016. ,
DOI : 10.1006/inco.1994.1093
URL : https://hal.archives-ouvertes.fr/hal-01246534
Uniqueness Typing for Functional Languages with Graph Rewriting Semantics, Mathematical Structures in Computer Science, vol.6, issue.6, pp.579-612, 1996. ,
Effect-dependent transformations for concurrent programs, Proceedings of the 18th International Symposium on Principles and Practice of Declarative Programming, pp.188-201, 2016. ,
DOI : 10.1145/2967973.2968602
URL : http://arxiv.org/pdf/1510.02419
Linearly used continuations, Proceedings of the Third ACM SIGPLAN Workshop on Continuations (CW'01). Citeseer, pp.47-54, 2000. ,
Linear Haskell: practical linearity in a higher-order polymorphic language, Proceedings of the ACM on Programming Languages, vol.2, issue.POPL, pp.1-5, 2018. ,
DOI : 10.1007/978-3-540-30557-6_8
URL : https://hal.archives-ouvertes.fr/hal-01673536
What is a categorical model of Intuitionistic Linear Logic?, Proc. TLCA, pp.78-93, 1995. ,
DOI : 10.1007/BFb0014046
Types are calling conventions, Proceedings of the 2nd ACM SIGPLAN Symposium on Haskell, pp.1-12, 2009. ,
Abstract, Journal of Functional Programming, vol.21, issue.02, pp.195-244, 1996. ,
DOI : 10.1007/BFb0013458
External Uniqueness Is Unique Enough, ECOOP 2003 -Object-Oriented Programming, 17th European Conference, pp.176-200, 2003. ,
DOI : 10.1007/978-3-540-45070-2_9
URL : http://homepages.cwi.nl/~dave/writing/papers/euiue.pdf
Ownership Types for Flexible Alias Protection, Proceedings of the 1998 ACM SIGPLAN Conference on Object-Oriented Programming Systems, Languages & Applications (OOPSLA '98), pp.48-64, 1998. ,
DOI : 10.1145/286936.286947
URL : http://www.cs.uu.nl/~dave/papers/ownership.ps.gz
Portable and high-level access to the stack with Continuation Marks, Ph.D. Dissertation. Northeastern University, p.45, 2006. ,
A tail-recursive machine with stack inspection, ACM Transactions on Programming Languages and Systems, vol.26, issue.6, 2004. ,
DOI : 10.1145/1034774.1034778
URL : http://www.ccs.neu.edu/scheme/pubs/cf-toplas04.pdf
A Theory of Effects and Resources: Adjunction Models and Polarised Calculi, Proc. POPL. https, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01256092
Abstract, The Journal of Symbolic Logic, vol.II, issue.03, pp.755-807, 1997. ,
DOI : 10.1007/BF00885763
URL : https://hal.archives-ouvertes.fr/inria-00528352
CPS transformation of beta-redexes, Information Processing Letters, vol.94, issue.5, pp.217-224, 2005. ,
DOI : 10.1016/j.ipl.2005.02.002
Bounding Data Races in Space and Time, Proc. PLDI, p.54, 2018. ,
Levity polymorphism, Proceedings of the 38th ACM SIGPLAN Conference on Programming Language Design and Implementation, PLDI 2017, 2017. ,
Adoption and Focus: Practical Linear Types for Imperative Programming, Proceedings of the 2002 ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI), pp.13-24, 2002. ,
Linear Regions Are All You Need Held as Part of the Joint European Conferences on Theory and Practice of Software, Programming Languages and Systems, 15th European Symposium on Programming Proceedings (Lecture Notes in Computer Science), Peter Sestoft, pp.7-21, 2006. ,
Type Classes for Lightweight Substructural Types, Proceedings Third International Workshop on Linearity, pp.34-48, 2014. ,
DOI : 10.1145/292540.292545
URL : http://arxiv.org/pdf/1502.04772
Linear logic, Theoretical Computer Science, vol.50, issue.1, pp.1-102, 1987. ,
DOI : 10.1016/0304-3975(87)90045-4
URL : https://hal.archives-ouvertes.fr/inria-00075966
A new constructive logic: classic logic, Mathematical Structures in Computer Science, vol.7, issue.2, pp.255-296, 1991. ,
On the unity of logic, Annals of Pure and Applied Logic, vol.59, issue.3, pp.201-217, 1993. ,
DOI : 10.1016/0168-0072(93)90093-S
URL : https://hal.archives-ouvertes.fr/inria-00075095
A formulae-as-type notion of control, Proceedings of the 17th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '90, pp.47-58, 1990. ,
DOI : 10.1145/96709.96714
Quantified types in an imperative language, ACM Transactions on Programming Languages and Systems, vol.28, issue.3, 2006. ,
DOI : 10.1145/1133651.1133653
Region-Based Memory Management in Cyclone, Proceedings of the, 2002. ,
DOI : 10.1145/512529.512563
URL : http://www.cs.cornell.edu/projects/cyclone/papers/cyclone-regions.pdf
A Proposal to Add Move Semantics Support to the C++ Language, p.14, 2002. ,
A Type System for Bounded Space and Functional In-Place Update, 2000. ,
The Zipper, J. Funct. Program, vol.7, issue.5, pp.549-554, 1997. ,
Cyclone: A Safe Dialect of C, Proceedings of the General Track: 2002 USENIX Annual Technical Conference, pp.275-288, 2002. ,
RustBelt: securing the foundations of the rust programming language, Proceedings of the ACM on Programming Languages, vol.2, issue.POPL, pp.1-66, 2018. ,
DOI : 10.1145/2500365.2500600
URL : https://hal.archives-ouvertes.fr/hal-01633165
Quasi-linear types, Proceedings of the 26th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '99, pp.29-42, 1999. ,
DOI : 10.1145/292540.292546
The linear abstract machine, Theoretical computer science, vol.59, issue.13, pp.1-2, 1988. ,
DOI : 10.1016/0304-3975(88)90100-4
URL : https://doi.org/10.1016/0304-3975(88)90100-4
A Generalization of Jumps and Labels, Technical Report. Subsequently published as Landin, p.45, 1965. ,
A Generalization of Jumps and Labels, Higher-Order and Symbolic Computation, pp.125-143, 1998. ,
The ZINC experiment: an economical implementation of the ML language, 1990. ,
URL : https://hal.archives-ouvertes.fr/inria-00070049
Call-by-Push-Value: A Subsuming Paradigm, Proc. TLCA '99, pp.228-242, 1999. ,
Call-By-Push-Value: A Functional/Imperative Synthesis, Semantic Structures in Computation, vol.2, issue.7, 2004. ,
Categorical semantics of linear logic, Panoramas et Synthèses, vol.27, pp.15-215, 2009. ,
Resource modalities in tensor logic, Annals of Pure and Applied Logic, vol.161, issue.5, pp.632-653, 2010. ,
DOI : 10.1016/j.apal.2009.07.018
Towards Alias-Free Pointers, ECOOP'96 -Object-Oriented Programming , 10th European Conference Proceedings (Lecture Notes in Computer Science), pp.189-209, 1996. ,
Real World OCaml -Functional Programming for the Masses, 2013. ,
Compiling with Types, p.51, 1995. ,
Formulae-as-types for an involutive negation, Proceedings of the Joint Meeting of the Twenty-Third EACSL Annual Conference on Computer Science Logic (CSL) and the Twenty-Ninth Annual ACM/IEEE Symposium on Logic in Computer Science (LICS), CSL-LICS '14, p.45, 2014. ,
DOI : 10.1145/2603088.2603156
URL : https://hal.archives-ouvertes.fr/hal-00996742
Syntactic Control of Interference Revisited, Theor. Comput. Sci, vol.228, pp.1-2, 1999. ,
Programming with permissions in Mezzo, ACM SIGPLAN Notices, vol.48, issue.9, pp.173-184, 2013. ,
DOI : 10.1145/2544174.2500598
URL : https://hal.archives-ouvertes.fr/hal-00877590
ASAP: As Static as Possible memory management, 2016. ,
A mechanized semantics for C++ object construction and destruction, with applications to resource management, ACM SIGPLAN Notices, vol.47, issue.1, pp.521-532, 2012. ,
DOI : 10.1145/2103621.2103718
URL : https://hal.archives-ouvertes.fr/hal-00674663
Syntactic Control of Interference, Conference Record of the Fifth Annual ACM Symposium on Principles of Programming Languages, pp.39-46, 1978. ,
A linear type system for multicore programming in ATS, Science of Computer Programming, vol.78, issue.8, 2013. ,
DOI : 10.1016/j.scico.2012.09.005
A dissection of L, 2014. ,
The design and evolution of C++. Pearson Education India, 1994. ,
Exception Safety: Concepts and Techniques, pp.60-76, 2001. ,
DOI : 10.1007/3-540-45407-1_4
URL : http://research.att.com/~bs/except.pdf
A brief introduction to C++'s model for type-and resource-safety. (2015). https://github.com, p.16, 2015. ,
A region inference algorithm, ACM Transactions on Programming Languages and Systems, vol.20, issue.4, pp.724-767, 1998. ,
DOI : 10.1145/291891.291894
URL : http://www.itu.dk/research/mlkit/kit_general/toplas98.ps.gz
Implementation of the Typed Call-by-Value lambda- Calculus using a Stack of Regions, Conference Record of POPL'94: 21st ACM SIGPLAN- SIGACT Symposium on Principles of Programming Languages, pp.188-201, 1994. ,
Practical affine types, Proceedings of the 38th ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, pp.447-458, 2011. ,
DOI : 10.1145/1925844.1926436
Linear Types Can Change the World!, Programming Concepts and Methods, p.15, 1990. ,
Substructural type systems, Advanced Topics in Types and Programming Languages, pp.3-44, 2005. ,
Safe Programming with Pointers Through Stateful Views, Practical Aspects of Declarative Languages, 7th International Symposium, PADL 2005 Proceedings (Lecture Notes in Computer Science), pp.83-97, 2005. ,
URL : http://www.church-project.org/reports/electronic/./Zhu+Xi:PADL-2005.pdf.gz
