New interface
Journal articles
Energy Efficient Scheduling and Routing via Randomized Rounding
Evripidis Bampis 1 Alexander Kononov 2 Dimitrios Letsios 3 Giorgio Lucarelli 4, 5 Maxim Sviridenko 6
3 COATI - Combinatorics, Optimization and Algorithms for Telecommunications
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
5 DATAMOVE - Data Aware Large Scale Computing
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : We propose a unifying framework based on configuration linear programs and ran-domized rounding, for different energy optimization problems in the dynamic speed-scaling setting. We apply our framework to various scheduling and routing problems in heterogeneous computing and networking environments. We first consider the energy minimization problem of scheduling a set of jobs on a set of parallel speed scalable processors in a fully heterogeneous setting. For both the preemptive-non-migratory and the preemptive-migratory variants, our approach allows us to obtain solutions of almost the same quality as for the homogeneous environment. By exploiting the result for the preemptive-non-migratory variant, we are able to improve the best known approximation ratio for the single processor non-preemptive problem. Furthermore, we show that our approach allows to obtain a constant-factor approximation algorithm for the power-aware preemptive job shop scheduling problem. Finally, we consider the min-power routing problem where we are given a network modeled by an undirected graph and a set of uniform demands that have to be routed on integral routes from their sources to their destinations so that the energy consumption is minimized. We improve the best known approximation ratio for this problem.
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/hal-01725140
Contributor : Lucarelli Giorgio Connect in order to contact the contributor
Submitted on : Thursday, March 8, 2018 - 10:55:59 AM
Last modification on : Friday, November 18, 2022 - 9:26:48 AM
Long-term archiving on: : Saturday, June 9, 2018 - 1:00:45 PM
File
journal-hal.pdf
Identifiers
Citation
Evripidis Bampis, Alexander Kononov, Dimitrios Letsios, Giorgio Lucarelli, Maxim Sviridenko. Energy Efficient Scheduling and Routing via Randomized Rounding. Journal of Scheduling, 2018, 21 (1), pp.35-51. ⟨10.1007/s10951-016-0500-2⟩. ⟨hal-01725140⟩
Share
Metrics
Record views
291
Files downloads
138
