Scheduling Parallel DAG Jobs Online to Minimize Average Flow Time, Proceedings of the Twenty-Seventh Annual ACM-SIAM Symposium on Discrete Algorithms, pp.176-189, 2016. ,
DOI : 10.1137/1.9781611974331.ch14
Energy-efficient algorithms, Communications of the ACM, vol.53, issue.5, pp.86-96, 2010. ,
DOI : 10.1145/1735223.1735245
Algorithms for dynamic speed scaling, STACS, pp.1-11, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00573591
On multi-processor speed scaling with migration, Proceedings of the 23rd ACM symposium on Parallelism in algorithms and architectures, SPAA '11, pp.279-288, 2011. ,
DOI : 10.1145/1989493.1989539
Speed scaling on parallel processors, SPAA, pp.289-298, 2007. ,
DOI : 10.1145/1248377.1248424
URL : http://ce.sharif.ac.ir/~ghodsi/archive/d-papers/SPAA/2007/Speed Scaling on Parallel Processors.pdf
Routing for Power Minimization in the Speed Scaling Model, IEEE/ACM Transactions on Networking, vol.20, issue.1, pp.285-294, 2012. ,
DOI : 10.1109/TNET.2011.2159864
Minimum-cost network design with (dis)economies of scale, FOCS, pp.585-592, 2010. ,
Speed Scaling on Parallel Processors with Migration, Euro-Par, pp.128-140, 2012. ,
DOI : 10.1007/978-3-642-32820-6_15
URL : https://hal.archives-ouvertes.fr/hal-00741604
Non-preemptive speed scaling, SWAT, pp.249-260, 2012. ,
DOI : 10.1007/s10951-013-0312-6
Hallucination Helps: Energy Efficient Virtual Circuit Routing, SODA, pp.1141-1153, 2014. ,
DOI : 10.1137/1.9781611973402.84
URL : http://epubs.siam.org/doi/pdf/10.1137/1.9781611973402.84
Competitive distributed job scheduling (extended abstract), Proceedings of the twenty-fourth annual ACM symposium on Theory of computing , STOC '92, pp.571-580, 1992. ,
DOI : 10.1145/129712.129768
URL : http://iew3.technion.ac.il/~kutten/zipped/djs.ps.gz
Energy Efficient Scheduling of MapReduce Jobs, Euro-Par, pp.198-209, 2014. ,
DOI : 10.1007/978-3-319-09873-9_17
URL : https://hal.archives-ouvertes.fr/hal-01020100
From preemptive to non-preemptive speed-scaling scheduling, Discrete Applied Mathematics, vol.181, pp.11-20, 2015. ,
DOI : 10.1016/j.dam.2014.10.007
URL : https://hal.archives-ouvertes.fr/hal-00867457
Green scheduling, flows and matchings, Theoretical Computer Science, vol.579, pp.126-136, 2015. ,
DOI : 10.1016/j.tcs.2015.02.020
URL : https://hal.archives-ouvertes.fr/hal-01366487
A note on multiprocessor speed scaling with precedence constraints, Proceedings of the 26th ACM symposium on Parallelism in algorithms and architectures, SPAA '14, pp.138-142, 2014. ,
DOI : 10.1145/2612669.2612672
URL : https://hal.archives-ouvertes.fr/hal-01215576
Properties of optimal schedules in preemptive shop scheduling, Discrete Applied Mathematics, vol.159, issue.5, pp.272-280, 2011. ,
DOI : 10.1016/j.dam.2010.11.015
URL : https://hal.archives-ouvertes.fr/hal-01306521
Improved bounds on Bell numbers and on moments of sums of random variables. Probability and Math, Statistics, vol.30, pp.185-205, 2010. ,
Energy Optimal Scheduling on Multiprocessors with Migration, 2008 IEEE International Symposium on Parallel and Distributed Processing with Applications, pp.153-161, 2008. ,
DOI : 10.1109/ISPA.2008.128
Stateof-the-art in heterogeneous computing, Sci. Program, vol.18, pp.1-33, 2010. ,
Deterministic load balancing in computer networks, SPDP, pp.50-57, 1990. ,
A survey of offline algorithms for energy minimization under deadline constraints, Journal of Scheduling, vol.24, issue.7, pp.3-19, 2016. ,
DOI : 10.1109/TPDS.2012.20
The bell is ringing in speed-scaled multiprocessor scheduling, SPAA, pp.11-18, 2009. ,
Geometric Algorithms and Combinatorial Optimizations, 2nd corrected edition, 1993. ,
Scheduling Heterogeneous Processors Isn't As Easy As You Think, SODA, pp.1242-1253, 2012. ,
DOI : 10.1137/1.9781611973099.98
Online Primal-Dual for Non-linear Optimization with Applications to Speed Scaling, WAOA, pp.173-186, 2012. ,
DOI : 10.1007/978-3-642-38016-7_15
On the Distribution of the Number of Successes in Independent Trials, The Annals of Mathematical Statistics, vol.27, issue.3, pp.713-721, 1956. ,
DOI : 10.1214/aoms/1177728178
Randomized rounding: A technique for provably good algorithms and algorithmic proofs, Combinatorica, vol.7, issue.4, pp.365-374, 1991. ,
DOI : 10.1007/978-1-4684-2001-2_9
URL : http://nma.berkeley.edu/ark:/28722/bk000579d87
Santa claus schedules jobs on unrelated machines, STOC, pp.617-626, 2011. ,
DOI : 10.1145/1993636.1993718
URL : http://www.nada.kth.se/nada/theory/projects/publications/SantaSched.pdf
Power-Aware Speed Scaling in Processor Sharing Systems, IEEE INFOCOM 2009, The 28th Conference on Computer Communications, pp.2007-2015, 2009. ,
DOI : 10.1109/INFCOM.2009.5062123
URL : https://authors.library.caltech.edu/18244/1/Wierman2009p8304Ieee_Infocom_2009_-_Ieee_Conference_On_Computer_Communications_Vols_1-5.pdf
A scheduling model for reduced CPU energy, Proceedings of IEEE 36th Annual Foundations of Computer Science, pp.374-382, 1995. ,
DOI : 10.1109/SFCS.1995.492493
URL : http://www.cs.pitt.edu/~kirk/cs3150spring2010/yds.pdf
