AntWMNet – A Hybrid Routing Algorithm for Wireless Mesh Networks Based on Ant Colony Optimisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Routing in wireless mesh networks is of paramount importance to their good performance. As this type of network is becoming key to many application scenarios, it is fundamental to guarantee that routing is as efficient as possible. Despite extensive research work carried out in the past, existing routing algorithms have problems in terms of latency, throughput, network overhead, and/or scalability, depending on their type. In the current paper we propose a hybrid wireless mesh networks routing algorithm that addresses the referred problems, exploring the ant colony optimisation paradigm. The algorithm, named AntWMNet, was extensively studied through simulation using OMNET++, and the results show that it clearly outperforms the reference AODV algorithm.
346846_1_En_8_Chapter.pdf (781.46 Ko) Télécharger le fichier
hal-01728793 , version 1 (12-03-2018)
Paternité
Luis J. Mariscal, Alicia Triviño, Fernando Boavida. AntWMNet – A Hybrid Routing Algorithm for Wireless Mesh Networks Based on Ant Colony Optimisation. 13th International Conference on Wired/Wireless Internet Communication (WWIC), May 2015, Malaga, Spain. pp.108-121, ⟨10.1007/978-3-319-22572-2_8⟩. ⟨hal-01728793⟩
63 Consultations
152 Téléchargements
