Free-form deformation parameterization for multilevel 3d shape optimization in aerodynamics, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00071565
Accelerating Evolutionary Algorithms With Gaussian Process Fitness Function Models, IEEE Transactions on Systems, Man and Cybernetics, Part C (Applications and Reviews), vol.35, issue.2, 2005. ,
DOI : 10.1109/TSMCC.2004.841917
Compressible flow solvers using unstructured grids, Research Report, vol.1732, 1992. ,
URL : https://hal.archives-ouvertes.fr/inria-00076971
Multi-level parameterization for shape optimization in aerodynamics and electromagnetics using particle swarm optimization, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00109722
Meta-modeling for robust design and multi-level optimization, 2007. ,
Single- and multiobjective evolutionary optimization assisted by Gaussian random field metamodels, IEEE Transactions on Evolutionary Computation, vol.10, issue.4, pp.421-439, 2006. ,
DOI : 10.1109/TEVC.2005.859463
URL : http://www.liacs.nl/~emmerich/pdf/ENG06.pdf
Curves and surfaces for computer-aided geometric design, 1989. ,
The particle swarm optimization in size and shape optimization. Structural and Multidisciplinary Optimization, 2002. ,
Design of optimal aerodynamic shapes using stochastic optimization methods and computational intelligence, Progress in Aerospace Sciences, vol.38, issue.1, pp.43-76, 2002. ,
DOI : 10.1016/S0376-0421(01)00019-7
Low-cost genetic optimization based on inexact pre-evaluations and the sensitivity analysis of design parameters, Inverse Problems in Engineering, vol.9, issue.4, pp.389-412, 2001. ,
DOI : 10.1080/174159701088027771
Aerodynamic shape design using evolutionary algorithms and new gradient-assisted metamodels, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.44-47, pp.6312-6329, 2006. ,
DOI : 10.1016/j.cma.2005.12.008
Multiquadric equations of topography and other irregular surfaces, Journal of Geophysical Research, vol.71, issue.8, pp.1905-1915, 1971. ,
DOI : 10.1029/JZ071i004p01105
A comprehensive survey of fitness approximation in evolutionary computation, Soft Computing, vol.9, issue.1, 2005. ,
DOI : 10.1007/s00500-003-0328-5
Computational Approaches for Aerospace Design, 2005. ,
DOI : 10.1002/0470855487
URL : http://doi.org/10.1002/0470855487
Particle swarm optimization, Proceedings of ICNN'95, International Conference on Neural Networks, 1995. ,
DOI : 10.1109/ICNN.1995.488968
A comparison of three methods for selecting values of input variables in the analysis of output from a computer code, Technometrics, vol.21, pp.239-245, 1979. ,
Genetic algorithms + data structures = evolutionary programs. AI Series, 1992. ,
An algorithm for selecting a good value for the parameter c in radial basis function interpolation, Adv. Comp. Math, vol.11, 1999. ,
Reconstruction of multivariate functions from scattered data ,
Free-form deformation of solid geometric models, ACM SIGGRAPH Computer Graphics, vol.20, issue.4, pp.151-160, 1986. ,
DOI : 10.1145/15886.15903
A modified particle swarm optimizer, 1998 IEEE International Conference on Evolutionary Computation Proceedings. IEEE World Congress on Computational Intelligence (Cat. No.98TH8360), 1998. ,
DOI : 10.1109/ICEC.1998.699146
Particle swarm optimization, AIAA Journal, issue.8, p.41, 2003. ,
Analysis of the particle swarm optimization algorithm, 2005. ,
Local error estimates for radial basis function interpolation of scattered data, IMA Journal of Numerical Analysis, vol.13, issue.1, pp.13-27, 1993. ,
DOI : 10.1093/imanum/13.1.13
Combining Global and Local Surrogate Models to Accelerate Evolutionary Optimization, and Cybernetics - Part C: Applications and Reviews ,
DOI : 10.1109/TSMCC.2005.855506
URL : https://eprints.soton.ac.uk/43820/1/zhou_07.pdf
