Multilevel Strategies and Hybrid Methods for Shape Optimization and Applications to Aerodynamics and Metal Forming, Evolutionary and Deterministic Methods for Design, Optimisation and Control with Applications to Industrial and Societal Problems Conference, 2005. ,
Approximation and Model Management in Aerodynamic Optimization with Variable-Fidelity Models, Journal of Aircraft, vol.0716, issue.6, pp.1093-1101, 2001. ,
DOI : 10.2514/6.1985-35
First- Order Model Management with Variable Fidelity Physics Applied to Multi- Element Airfoil Optimization, 2000. ,
Eds., chapter Shape Optimization in One Shot, 1995. ,
Borz`?. Multilevel Methods for Optimization and Inverse Problems, SIAM Annual Meeting, 2006. ,
Introduction to Optimization and Multidisciplinary Design, J. Périaux and H. Deconinck Eds., chapter Hierarchical Methods for Shape Optimization in Aerodynamics ? II: Additive Methods in Aerodynamics. Lecture Series 2006-3, 2006. ,
Hierarchical Principles and Preconditioning for Optimum Design and Identification, Innovative Tools for Scientific Computation in Aeronautical Engineering, Handbooks on Theory and Engineering Applications of Computational Methods, 2001. ,
Two-Level Ideal Algorithm for Parametric Shape Optimization, Advances in Numerical Mathematics Proc. of two International Conferences: Moscow, Institute of Numerical Mathematics , Russian Academy of Sciences, pp.65-85, 2006. ,
Numerical Methods for Scientific Computing, Variational Problems and Applications eds., chapter Hierarchical Optimum-Shape Algorithms Using Embedded Bézier Parameterizations, CIMNE, 2003. ,
Nested and self-adaptive B??zier parameterizations for shape optimization, Journal of Computational Physics, vol.224, issue.1, 2007. ,
DOI : 10.1016/j.jcp.2006.12.016
Introduction to Optimization and Multidisciplinary Design, J. Périaux and H. Deconinck Eds., chapter Hierarchical Methods for Shape Optimization in Aerodynamics ? I: Multilevel Algorithms for Parametric Shape Optimization, Lecture Series 2006-3. Von Karman Institute for Fluid Dynamics, 2006. ,
Multilevel Shape Parameterization for Aerodynamic Optimization ? Application to Drag and Noise Reduction of Transonic/Supersonic Business Jet, European Congress on Computational Methods in Applied Sciences and Engineering, pp.24-28, 2004. ,
Adaptive Parameterization Using Free-Form Deformation for Aerodynamic Shape Optimization, Research Report, vol.5949, 2006. ,
DOI : 10.1051/proc:072221
URL : https://hal.archives-ouvertes.fr/inria-00085058
Curves and Surfaces for Computer-Aided Geometric Design ? A Practical Guide, 1990. ,
Aerodynamic Design via Control Theory, Journal of Scientific Computing, vol.3, pp.97-0101233, 1988. ,
DOI : 10.1007/978-3-642-83733-3_14
URL : http://aero-comlab.stanford.edu/Papers/jameson_jsc_1988.pdf
Optimum Aerodynamic Design Using the Navier-Stokes ' Equation. Theorical and Computational Fluid Dynamics, pp.213-237, 1998. ,
DOI : 10.2514/6.1997-101
URL : http://aero-comlab.stanford.edu/Papers/reno97.nsdesign.pdf
A multigrid approach to the optimization of systems governed by differential equations, 8th Symposium on Multidisciplinary Analysis and Optimization, 2000. ,
DOI : 10.1080/10556780008805795
Model Problems for the Multigrid Optimization of Systems Governed by Differential Equations, SIAM Journal on Scientific Computing, vol.26, issue.6, pp.1811-1837, 2005. ,
DOI : 10.1137/S1064827502407792
A Simplex Method for Function Minimization, The Computer Journal, vol.7, issue.4, pp.308-313, 1965. ,
DOI : 10.1093/comjnl/7.4.308
Multidisciplinary Aerodynamic-Structural Shape Optimization Using Deformation (massoud) In 8th AIAA, ISS, MO Symposium on Multidisciplinary Analysis and Optimization, 2000. ,
DOI : 10.2514/6.2000-4911
URL : http://hdl.handle.net/2060/20000099746
Free-form deformation of solid geometric models, Item: Courses), pp.151-160, 1986. ,
DOI : 10.1145/15886.15903
URL : http://tom.cs.byu.edu/~tom/papers/ffd.pdf
AlgorithmesévolutionnairesAlgorithmesévolutionnaires pour le calcul scientifique : Applicationàplicationà l'´ electromagnétisme etàetà la mécanique des fluides, p.6, 1998. ,
A Hierarchical Genetic Algorithm Using Multiple Models for Optimization, Proceedings of the 6th International Conference on Parallel Problem Solving from Nature, pp.879-888, 2000. ,
DOI : 10.1007/3-540-45356-3_86
An Introduction to Multigrid Methods Corrected Reprint, 1992. ,
