Slice Orchestration for Multi-Service Disaggregated Ultra Dense RANs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Magazine Année : 2018
Chia-Yu Chang
  • Fonction : Auteur
Navid Nikaein
  • Fonction : Auteur
  • PersonId : 868226
Adlen Ksentini
Ultra Dense Networks (UDNs) are a natural deployment evolution for handling the tremendous traffic increase related to the emerging 5G services, especially in urban environments. However, the associated infrastructure cost may become prohibitive. The evolving paradigm of network slicing can tackle such a challenge while optimizing the network resource usage, enabling multi-tenancy and facilitating resource sharing and efficient service-oriented communications. Indeed, network slicing in UDN deployments can offer the desired degree of customization in both vanilla Radio Access Network (RAN) designs, but also in the case of disaggregated multi-service RANs. In this article, we devise a novel multi-service RAN environment, i.e., RAN runtime, capable to support slice orchestration procedures and to enable flexible customization of slices as per tenant needs. Each network slice can exploit a number of services, which can either be dedicated or shared between multiple slices over a common RAN. The novel architecture we present concentrates on the orchestration and management systems. It interacts with the RAN modules, through the RAN runtime, via a number of new interfaces enabling a customized dedicated orchestration logic for each slice. We present results for a disaggregated UDN deployment where the RAN runtime is used to support slice-based multi-service chain creation and chain placement, with an auto-scaling mechanism to increase the performance.
orchestration-ran-slicing.pdf (1.9 Mo) Télécharger le fichier
hal-01730597 , version 1 (13-03-2018)
Chia-Yu Chang, Navid Nikaein, Osama Arouk, Kostas Katsalis, Adlen Ksentini, et al.. Slice Orchestration for Multi-Service Disaggregated Ultra Dense RANs. IEEE Communications Magazine, 2018, 56 (8), pp.8. ⟨10.1109/MCOM.2018.1701044⟩. ⟨hal-01730597⟩
433 Consultations
812 Téléchargements
